Hawk Brake Pads Squeal
mine continue to do it after taking them back off greasing the hell out of them with brake lube, and ati squeal and using fiber shims. they are actually louder now if I have to stop real fast it sounds like my damn left front wheel is gonna fall off. i gave up a long time ago thinking it would stop.
I just installed all four corners with HPS and the all sqeal like crazy when I stop hard from high speed. At normal driving condition, no sqeal at all. I gotta go to AutoX tomorrow. Kinda embrassing.
Originally Posted by Dream Came True
Questin:The set for the rear did not come with the pin that suppsed to start sqealing when the pads are low. The front set did. Did I get a bad set?
which hawk pads. the HP pads will make noise til you heat them up, thats the nature of the metalic pad. you sacrifice noise for stopping ability! the HPS pads should be silent. if they are not, i dont think they were installed properly. did you replace or turn your rotors wehn you put the new pads on? you should have atleast sanded the rotor with a piece of 80 grit sandpaper for a second. that allows it to seat better! pull the pads off and sand it real quick. you can also add some "anti-squeel" the the back of the pads (between the pads and the caliper) that will remove any of the sound that is caused by the pads vibrating against the caliper!
I had project mu installed on all four. And it only sqeals when I brake softly, like slowing down from 25mph to a stop.
I was leaving the movies last night and it was cold outside, I get in the car and drive off, step on the brakes OOMMGG sqeekkkkkkkkk!
eevverbody looked at me like what the **** is wrong with your car, haha.
Hey how's it going? Yeah I remember the meet at the cheesecake factory, your name again?
I dont know what is causing this. I am thinking that maybe they need to warm up or something, but even after driving for half an hour they still squel when coming to a stop.
4g63xawd
62
Jan 6, 2016 03:25 AM
xbox4414
15
Sep 22, 2008 09:15 PM
Jeffs2006EVOIX
23
May 14, 2008 01:17 PM
