Looking for concaved rims
Old Oct 4, 2006 | 09:49 PM
  #76
Touaman's Avatar
Hey guys, let me know if this helps at all in regards to offsets of rims.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Dec 7, 2006 | 09:10 AM
  #77
hokiruu's Avatar
Came accross this thread searching for people's 17x10 setups. I see alot of people just asking "what wheels do I get for this look?" etc. What you should be asking yourselves is: how do I need to set up my suspension, what wheel specs, what tires do I want to or have to run, and do I have to do any fender modification, and if so, what kind?" Sounds like alot, and I'm not saying you have to do ALL of these things, but they are all factors.
I have a few additional comments to make regarding the issue.
For a real concave look, low offset (30mm or less) and relatively wide (9" or more) width wheels are often necessary. While it is true that some wheel designs are more concave than others in any offset, and some become more or less concave than others as you decrease offset and increase width, there aren't many higher offset wheels that "just have that look" in whatever size, especially something close to stock Evo specs (17x8 +38). Cars with high offsets almost never have really concave spokes unless they are wide body and/or insane negative camber.
In short, if you want real concave or flush wheels you will have to WORK for it which is why it's coveted and not everyone has it
Here are a few things I am surprised nobody has brought up.
I see alot of people disagreeing over what fits, what rubs, etc. throwing out offsets and widths, but few are addressing two of the major factors in making wheels fit:
TIRE SIZE- alot of the flushed-out, super concave setups you see on drift or european cars are running stretched tires i.e. a tire that would fit on a much narrower rim stretched over a much wider rim. This has a whole series of pros and cons that I won't get into.
NEGTIVE CAMBER- sure, that guys is running "XX" wheel dimensions, offset, and tire, but what camber are they running? Camber makes a huge difference in what fits, handling, and tire wear.
FENDER WORK- This can go beyond just rolling. Evo rear fender options are somewhat limited due to the chassis design. Fenders can be rolled, over fenders added, or "pulled" although pulling is more difficult and the results are somewhat limited on sedans like the Evo because there is a door in front of the wheel well.
I know this sounds like alot, and you probably don't need even half of it on your car, but they are all things to consider. I just want to encourage people to think beyond the "what single answer for this result" approach.
Old Dec 23, 2006 | 12:07 AM
  #78
Ryan Devera's Avatar
Old Dec 23, 2006 | 02:24 AM
  #79
hokiruu's Avatar
and that there would be a NOT concave wheel!
Old Dec 25, 2006 | 09:17 AM
  #80
D Block's Avatar
advan rs gunmetal 18x9 with a 29 offset-major concave.
Old Dec 26, 2006 | 01:24 AM
  #81
Paikman GTR's Avatar
TE37 and Work Emotion CR for the win.
Old Dec 26, 2006 | 09:50 AM
  #82
TURBevO8's Avatar
Old Dec 26, 2006 | 12:37 PM
  #83
ls180sx's Avatar
- offsets ftw!
Old Jan 7, 2007 | 09:20 AM
  #84
BoOsTinGEVO190's Avatar
how about these wheels some nice rota
Old Jan 7, 2007 | 05:10 PM
  #85
hokiruu's Avatar
oh, and if you want really concave wheels and flush fitment, you will pretty much have to disregard what the tirerack tells you. they go with what fits the easiest and safest, which is what makes sense for them. but they won't tell yu to get what you need to get that sick face and fitment! in fact they will recommend against it.
Old Jan 7, 2007 | 07:09 PM
  #86
hawaiievo's Avatar
heres mine 17x9 +29 offset GT-R face
Old Jan 7, 2007 | 07:37 PM
  #87
xepyt's Avatar
Originally Posted by NOLIMITMOTORS
I WANT TO KNOW EXACTLY WHAT THESE ARE AS FAR AS WIDTH AND OFFSET. SOMEONE SAID 18X9 WITH +31MM BUT IS THAT DEFINITE???
i made a post about this check it out and you'll find all the info you need
https://www.evolutionm.net/forums/sh...d.php?t=128566
CrossRifles
Dec 14, 2012 11:12 PM
CarbonEvoFiber
75
Oct 20, 2012 06:00 PM
CarbonEvoFiber
Mar 12, 2011 01:10 PM
ChadB
For Sale - Wheels / Tires
27
Sep 19, 2009 06:35 AM
dreamevo
May 3, 2009 03:10 PM
