Front Driver Side Rotor
Old Nov 27, 2005 | 07:42 PM
humpevo311's Avatar
Originally Posted by EVO316
Ewww, so im not the only one this has happened to. Ill do some hard braking tomorrow and also take it to the dealer to see if there is anything wrong with the rotor or pad.
Thanks for responding
Take the car to about 40 miles and hour and do some semi agressive brake, bring the car to a fairly quick stop but dont mat them. Do this about 10 times giving them plenty of time to cool between this time. Then do the same thing from about 55-60 but only 2 or 3 times. Then check. This is how I break in new pads which is what your car has. If it dosent seem like its going away at all take it to the dealer.
Old Nov 27, 2005 | 07:50 PM
EVO316's Avatar
Thanks for the advice humpevo311!
Old Nov 28, 2005 | 07:58 AM
PA-silver03evo's Avatar
Yes, it was also the drivers side. You can do some hard braking if you want to try to speed up removing the line. Although it wont hurt anything with it being there so if you want, you can just keep driving regular and normal wearing of brakes will remove it.
PA-silver so your evo did the same thing? Was it the driver's side rotor also. Do you think I should do some HARD braking to see if the pad finally makes some contact to get rid of that ugly line???
Old Nov 28, 2005 | 08:45 AM
Kayaalp's Avatar
48 views and no opinions???
Stop freaking out. Something (probably a rock) got stuck between the pad and rotor surface and gouged the rotor. This happens all the time. It's one of the downsides of having huge, multi-piston calipers: the top is open (to allow pad changes) and therefore exposed to the elements.
No big deal.
Emre
GGMoe
Lancer Troubleshooting
Jul 12, 2016 01:03 PM
Evo Eric
32
Apr 7, 2016 01:35 PM
MitsuJoe
468
Feb 20, 2016 11:17 AM
nickolime
Sep 1, 2015 08:19 AM
MitsuJoe
Aug 1, 2004 01:59 PM
