top hats and camber plates
Old Nov 29, 2005 | 04:29 PM
leif's Avatar
who makes the best ones? i need something for my ohlins. i was going to get the works rear top hats but i noticed that tein makes some for about 100 bux less... is there any real difference? i don't mind paying for quality, but i cant see how one would be better than another.
and are all camber plates equal? ground control seems to make the most advanced..with castor control and what not, but i havent heard of anyone running them.
Old Nov 29, 2005 | 04:35 PM
bobaab's Avatar
http://www.top-hats.com/
Old Nov 29, 2005 | 04:36 PM
chronohunter's Avatar
Originally Posted by bobaab
Old Nov 29, 2005 | 04:37 PM
chmodlf's Avatar
Off topic but what spring rates did you get for the Ohlins? Why did you get rid of the JICs?
Old Nov 29, 2005 | 05:02 PM
RallySport Direct's Avatar
Silver Sponsor
Tein and cusco make some good top hats. Quality is great on them
I have heard nothing but good things from works products though I have not been able to test them personally yet.
If you want caster control then I would recommend the ground controls. If not teins and cuscos will do what you need.
Ben
Old Nov 29, 2005 | 07:11 PM
leif's Avatar
the spring rates are chronohunter/vishnu spec, i dont know if they are cool with me giving them out, sorry. im getting rid of the jics as they are not a serious track set up and are more suited for the street.
ben...does cusco make rear top hats? i just see the camber plates on your and everyone else's website. it looks like the only top hats made in the industry are tein and works.
Old Nov 30, 2005 | 09:10 AM
Silver Sponsor
Sorry cusco only makes a front you would need to go with a different company for the rears.
Ben
Old Dec 4, 2005 | 07:45 AM
tuner's Avatar
Rear Top Hats
AFAIK the Teins and the Works are the same so I bought the Teins (much cheaper) which look to be very nice.
I have the front Ground Control camber plates (top mounted) and find that though they have caster adjustment, I can still not get max. stock spec. caster when the adjusters are set in maximum position. If I did some grinding of some metal on the body I might get a bit more.
If you go to the GC setup and use Ohlins, be sure they provide the proper top perch (top hat) which is machined with a large taper on the bottem in order to fit down onto the Ohlins strut. Otherwise your top strut nut will not thread-in enough and will keep working loose.
Old Dec 4, 2005 | 08:40 AM
evoracerx's Avatar
I have the tein camber plates and rear pillowball mounts. Same thing as the Works. Have had them on for 6 months without any problems or noise
Old Dec 4, 2005 | 09:55 AM
Silencer's Avatar
I have the Works front camber plates and custom Works rear upper pillow ball joints. Excellent pc's!
Dave
Old Dec 4, 2005 | 04:21 PM
Z1 Performance's Avatar
might want to ask Ohlins which fit...I thought I recalled compatibility issues with some mounts (could be mistaken)
Old Dec 5, 2005 | 11:35 AM
Noob4life's Avatar
Not at all, but to determine whats good and bad you need to know what to look out for.
Old Dec 5, 2005 | 12:50 PM
marksae's Avatar
The camber plates that came w/ my Zeals don't really allow too much negative camber. I'm at -2.5° right now and they're almost all maxed out. And this is w/ the strut-to-hub camber adjustment bolt on the aggressive setting.
Old Dec 5, 2005 | 01:27 PM
leif's Avatar
i ordered the tein stuff...sounds like it'll fit...altho ill be pissed if i cant get 3 degrees up front. my ohlin wont be put together for a few more weeks because im waiting on various parts but ill let everyone know how they work when its all said and done.
pooster.online
May 26, 2016 09:16 AM
Anexos
Aug 14, 2012 12:30 PM
FERNO
Feb 14, 2012 12:06 PM
Vostok 7
10
Jan 6, 2008 03:52 PM
jkim2001
Mar 7, 2007 04:47 AM
