shaking
Old Dec 9, 2005 | 01:02 PM
bby evo's Avatar
shaking
my car starts to shake when i go over 40mph i checked the rims and they were fine and the allignment is fine. can anyone help me if you know what the problem might be
Old Dec 9, 2005 | 01:21 PM
Aikido's Avatar
check if you have ice build up in your control arms and then just take it to a wash a spray it off, happened to me last year. hope that helps
Old Dec 9, 2005 | 01:24 PM
Cali2MDevo8's Avatar
Registered User
how about getting the wheels balanced. Check to see if all the wheel weights are still on. Not an alignment issue really. More of a balance issue. Speed balance will help. Mr.Tire does a speed balance.
Takes the wheeel up to 60 MPH and balance's them. Works pretty good.
travelsize420's Avatar
an unbalanced tire can't be discovered by "checking the rims".
i had an unbalanced tire and my car shook after 60 mph.
its a quick fix if thats your problem
Old Dec 9, 2005 | 01:30 PM
ray3328's Avatar
Yup, get your wheels balanced.
Old Dec 9, 2005 | 01:34 PM
EvoJutsu's Avatar
Shake like in the whole car shaking? Cause my pops got ihs wheels balanced and then i forgot what they did exactly, but they put the wheels on so tight. The whole car use to shake... we jus went back and told em to loosen it up.
Old Dec 9, 2005 | 01:40 PM
Curt@MrLed's Avatar
Former Vendor
can we really help, no, we can only speculate..
Old Dec 9, 2005 | 01:43 PM
4e0v8o's Avatar
True.
Old Dec 9, 2005 | 01:46 PM
Fireball's Avatar
Most likely you threw a wheel weight...
I see that you live in IL, so most likely either you've been driving in the snow and packed the wheels with ice, which will cause the shake, or in the process of driving through the snow, you knocked a wheel weight off the car.
Old Dec 9, 2005 | 02:51 PM
05SilverEvoVIII's Avatar
road force balance
my guess is that your car was or has been sitting for a little while causing faulty and irregular weights on the wheels and thus you need to have a road force balance which is a new machine for this year and corrected mine.
Old Dec 9, 2005 | 02:57 PM
Enyth's Avatar
does it only happen when you accelerate above that speed? meaning, starts shaking when accelerating and then stops shaking when off the accelerator?
Old Dec 9, 2005 | 02:59 PM
DevilsEvo666's Avatar
It could either 2 things...Unbalanced tires OR you could have flat spots on certain parts of your tires...Flat spots occur if the car has been sitting for a while and has not moved..But the car has to be sitting for a LONG time to develop flat spots...Or the tires mite have a shifted belt inside the tire and that means you will need to purchase a new tire(s)..Just take it to a mechanic and let him give u his opnion
Old Dec 9, 2005 | 03:02 PM
Links0000's Avatar
Ya if your in illinois with that snow storm that just came through its prob ice build up. Mine was shaking horribly this morning when i got to 40. I was freaking out but after parking in my schools auto garage to look for a flat or unbalanced wheels I realised it was just the snow. Sprayed it off and it was gone. Hope thats the only problem with yours.
Old Dec 10, 2005 | 11:56 AM
bby evo's Avatar
thanks it was just because there was ice build up i took it to the wash and no it is working fine.
