Hawk brake pads = garbage!
Old Jul 18, 2006 | 12:08 PM
  #31
FCobra94's Avatar
Originally Posted by justchil
Project MU NS will squeek if not installed "properly" I love mine though. Same is probably true with the Hawk HPS pads.
I don't have first hand experience with the EVO braking system (front or rear), but if the rear pads on the EVO are shaped like the ones pictured above YOU ABSOLUTLY NEED TO USE SHIMS WHEN INSTALLING THEM!!!
Countless cars use that style of brake pad for the rear and if you don't install a shim along with them they will squeal like crazy! There is no amount of "brake lube" that will help either. Ask me how I know
I just tackled this EXACT problem with my daily driver (Volvo). It's only a ~$10 fix too with the shims being available right through NAPA:
Brake Shims
Anyways, I have personally had no problems with Hawk pads and since it seems to be hit or miss around here, I am almost 99% sure that shims (whether they be stainless, fiber, etc.) will solve your problem
Old Aug 28, 2006 | 08:21 PM
  #32
rice_rocket88's Avatar
I was bedding mine in tonight, and once they got hot they squeaked like a @#$@#$. I saw that some people say they squeak only when they get hot.
Don't know if I was paranoid at all, but I also got a tiny "clunk" out of the car when backing out of a stall.
I have triple checked the pads/calipers for the pins and the springs as well as that the pads are seated properly. I know my tranny clunks itself, but the clunk seemed to come from the rear brakes.
Otherwise, they are quiet so far for normal driving.
Old Aug 28, 2006 | 09:11 PM
  #33
trinydex's Avatar
the hawks squeek at low speed, at high speed and high temp theyre pretty quiet unless you have dtc series hawks, in which case you wouldn't be driving them on teh street.
the clunk is also norm for hawk pads... for some reason they make them too small or something. just means you need to use more brake disc quiet next time.
Old Aug 28, 2006 | 09:15 PM
  #34
Great.. it's pretty darned quiet for me so far. I used plenty of the grease, I thought maybe it was too much and it was sliding Good to know that it's just the tiny bit of difference in size.
Old Aug 28, 2006 | 09:20 PM
  #35
trinydex's Avatar
actually i don't know where people got the idea to use grease to install pads. brake disc quiet is a sealant type texture goo and dries like caulking so it sticks and after it dries it dampens vibrations that would cause noise.
grease doesn't stick... neither does it have proper vibration damping characteristics that insulation materials have.
Old Aug 28, 2006 | 09:41 PM
  #36
hondafan's Avatar
i thought the hawk pads came with shims on the pads already so there is no need to use the stock ones? also, i see most people use copper anti-sieze on the pads, but i do have some of the disc brake quiet, so maybe i'll try that.
Old Aug 28, 2006 | 09:46 PM
  #37
Those aren't shims, they are the backing on the brake pads. The shims come off and have an arrow cut into them. The stock pads also have this metal backing... plus those shims that you are supposed to transfer over.
Old Aug 28, 2006 | 09:49 PM
  #38
lazyevo's Avatar
lancershop.com has oem pads
Old Aug 28, 2006 | 09:54 PM
  #39
hondafan's Avatar
ahh, i see. i'll be doing the brakes next week, so this is good to know. anywhere we can buy a new set of shims from besides ?
Old Aug 29, 2006 | 05:58 AM
  #40
Hawk sells their own, but it's like 65 for the set... I don't see a reason why you can't use the stock ones. Assuming your car is still stock, if they don't have 'em in there I'd ***** at the dealership.
Old Feb 6, 2007 | 06:22 PM
  #41
malicious_alx's Avatar
Did you remember to resurface your rotors?
Old Feb 8, 2007 | 06:36 AM
  #42
emolution's Avatar
i have hawks and the dealer put them in and i broke them in just like the "instructions" said, but they still sound like a freakin hawk dying.... i guess thats why they have their name.... and they suck compared to my stockers.
Old Feb 8, 2007 | 06:40 AM
  #43
laakness's Avatar
Originally Posted by BaLListic_EVO
yeah mine squeak time to time but i have had them on the car for 40k miles! i personally couldnt be happier.. they have basically no fade and worked excellent @ my last auto-x. but they arent nearly as harsh on the rotors as stock and take forever to wear out where as the stockers went around 20k.....
Very true! Everytime I have my wheels off I am amazed at how little they wear yet not tear up the rotors.
Old Feb 9, 2007 | 11:03 AM
  #44
V.8MR's Avatar
I love my HP+ for the track. Very noisey but i havent seen an evo with agressive pads that isnt loud. Shoot even the stock pads make noise sometimes. Its called brembo squeal, im proud of the sound. It means i have some damn good brakes.
Old Feb 9, 2007 | 11:07 AM
  #45
KartaRailed's Avatar
If you want the absoloute best way to stop that annoying high pitched squeaking sound, just go to NAPA, get a can of 10w30 synthetic motor oil, and pour it all over your calipers, pads, and rotors, thats the only surefire way to stop the squeaking.
