Voltex Setup: Final decision exposed!
Old Feb 25, 2006 | 06:13 PM
S2Kstephen's Avatar
Originally Posted by jbigelow
hey s2kstephen,
tell francis @ a-spec that you will need a reverse stagger for the evo, so it would be the 18x10 in the front and 18x9 in the rear. hueman is correct on why they do the reverse stagger for the evo.
if you want, i have an extra set of advan rs gunmetal wheels that will be available soon for our widebody fenders. 18x10 all around just like the original runduce evo.
let me know if interested, if not good luck on your car and can;t wait to see the finished product.
-jbigs
jBigs,
Your right, I missed labeled the wheels in my original post. The 18x10 is the front/18x9 is the rear.
PM'd you.
-Stephen
Old Feb 25, 2006 | 06:16 PM
housedj's Avatar
Originally Posted by hueman
hey stephen, have you thought about doing the front wider than the rear? i know a lot of competition shops in japan do it because of our 60/40 weight bias and it's supposed to help.
it actually improves handling on the evos since they still understeer a little even with coilovers. cyberevo runs 20mm wider in the fronts than the rear...
Old Feb 27, 2006 | 01:28 AM
trinydex's Avatar
running staggered is only good for stuff like autocross as staggered offset and staggered tire sizes eventually lead to reduced lateral g potential which is what determines the ultimate level of grip which is what in turn produces a win. if you're gonna go wider try to go wide all around. and if wheels nad tires are the only way you know how to get a car to rotate someone else needs to be doin' yer suspension.
also don't you wanna be able to rotate your tires? running staggered offset wheels means you can't. which is a total waste if you'r enot even gonna stagger wheel size... if you're running hte same wheel size might as well run the same offset and spacers.
Old Feb 27, 2006 | 09:59 AM
Z1 Performance's Avatar
18x10 +17 is not even going to come close to fitting, even with widest of wide fenders out there - you are talking about 25mm more outwards than even an 18x9 +29 wheel, which already sits pretty flush to the front fenders - you are going to need in the area of a 25mm wider than stock fender
Old Feb 27, 2006 | 10:03 AM
93civEJ1's Avatar
Originally Posted by evo150
those there are pure sex~!
Galaxshiel
For Sale - Cars For Sale
Dec 4, 2016 06:53 PM
jay777
Mar 16, 2014 05:29 PM
TeRoy EvoIX
Jul 17, 2013 03:28 PM
Evasive EVO
Evo 'For Sale' Exterior Styling
21
Dec 6, 2010 06:19 PM
Speed Element
Nov 26, 2007 02:48 PM
