Stiff coilover spring rates and ABS....
Wondering when driving around town have you guys noticed your ABS coming in much quicker now due to your stiffer suspension?
Specially after my RRE rear sway my rear wheel goes off the ground on the slightest driveways/ inclines and you feel the ABS kick in.....
For the springs and damping though maybe ABS can come in handy, along the lines of Koni's recommendations. Disconnect your sway bars and do some hard braking on a bumpy surface. Adjust your damping to minimize ABS engagement. Then you're doing your best at keeping all the wheels on the ground, at least under those conditions.
Dave
As djh said, ABS only kicks in when you are losing traction. It seems the way your suspension is set up your car is losing traction during certain conditions ... adjust your suspension for those conditions and ABS may go away ....
xceler8rob
Feb 29, 2016 09:58 AM
EvoDan2004
20
Nov 20, 2011 06:05 AM
