Trouble getting Evo's aligned that have coilovers
Guys with coilovers....
Are you having trouble finding someone that is competent enough to align your car? I have had my alignment done twice by the same shop. They put a 6 month 6,000 mile warranty on the alignment, but my rear tires are corded already after only a month and a half of driving (they were brand new at the time of the alignment).
Can you tell me who you guys are having your alignments done by? FYI- I have HKS Hipermax coilovers. With the front ride height at the stock HKS ride height and I raised the rear about a half inch from the stock HKS setting. My rear tires are so severly toed out that you can actually see it. It is horrible.
What specs were you aligned to? If you are running lots of toe (in or out) you will be scrubbing tire all the time and it is the quickest way to destroy tires. Honestly, alignment on these cars isn't very difficult, there are no special tricks.
Registered User
Toe and camber are the major components of an alignment. Too much negative camber and the toe being inward will cause major wear on the inside of the tire. I had major problems w/ my civic w/ the same problem. Ever since i'm weary about dropping my evo.
You may need camber plates. The shop can print you out your alignment specs, then just go from there.
i just had my car aligned with the hipermax rs coilovers and after they did it i found out my right side shock was leaking...so i have to wait 2-4 weeks to be repaired. But when you got your alignment, did they loosed the camber bolts on top of the ball mounts? i know they didnt do it for me when they aligned it, but since my shock leaked right after i have had no time to figure it out.
Well my car keeps loosing it's settings. I dont have the print out with me, but it was a good alignment. I am trying to figure out why my car will align okay, but then a month later everything be off again.
John
TxFAkuma
Feb 17, 2017 03:45 PM
helios-73
Jan 13, 2016 10:40 PM
ApexScalpel
Oct 3, 2011 09:37 PM
lan_evo_mr9
19
Feb 10, 2007 03:15 PM
Shingen
28
Dec 20, 2005 06:07 AM
