suspension question
suspension question
I have finished my exhaust install, and I am getting a rattling underneath. I don't think that I have my factory cross bars under the motor spaced down far enough. anyone know if there will be any issues driving the car for a day without them installed? it's the 2 cross bars that bolt across the frame under the tranny/motor. one has 2 bolts, one has 3.
I don't see an issue as long as you don't corner like your auto-xing..
any thoughts?
any thoughts?
It'll reduce the handling. Look into an aftermarket lower arm bar - some are designed to work with aftermarket exhausts, and you will maintain or enhance handling characteristics.
http://www.rallysportdirect.com/shop...roducts_id/564
cusco I believe makes a set of bars that will clear anything aftermarket, but I think all I need are some larger spacers for the factory bars. I am currently using 2 washers for each bolt. have a friend with a cnc machine that can make me some spacers
TronCarterIII
Nov 25, 2016 08:05 PM
harrisonk531616
21
Dec 13, 2009 07:01 AM
Yeah, it won't do anything for a few days...might notice it a little if you really push it, but other than that you shouldn't notice a thing!
