WORKS chassis stiffening
Old Oct 16, 2006 | 10:24 AM
06redMR's Avatar
aaaaaaaaaaaaaaalright so these are my choices for chassis stiffening . im posting this just incase anyone has expereinced problems with these peices or has heard anything bad about them. if there are only good things to say about these peices im buying them this week.
http://www.worksevo.com/store/produc...roducts_id=266
http://www.worksevo.com/store/produc...products_id=39
http://www.worksevo.com/store/produc...roducts_id=309
(no drop bars or RS bar)
let me know what u think guys. thanks !
Old Oct 16, 2006 | 11:56 AM
redvolution's Avatar
I noticed an improvement with the Croxx plate over the factory tie bars (I have a 3" downpipe and the fit is perfect).
Why do you want the front strut bar? It doesn't add rigidity over the stock bar. The rear bar, on the other hand will help. Unlike most rear bars it lacks hinges. Note that the Ralliart rear bar also lacks hinges.
Old Oct 16, 2006 | 12:11 PM
Boosted GP's Avatar
I have both the front and rear strut braces, all I can say is WOW!!!! I am a perfectionist and an engineer (a combonation to drive you crazy) but I was well impressed by the quality, finish and service of all my works products. WORKS has possibly the best parts available on the Planet.
Here is a better pic of the front brace for you, and one of the rear
Mike
Old Oct 16, 2006 | 12:17 PM
Czubaka's Avatar
Great job on that rear STB install!
Old Oct 16, 2006 | 12:21 PM
speedomodel's Avatar
Wow! that's beautful.
Old Oct 16, 2006 | 12:24 PM
caswanso's Avatar
Very clean.
Old Oct 16, 2006 | 12:30 PM
stevEVO8's Avatar
Does the rear works piece come with that rubber grommet or did you make that??
Old Oct 16, 2006 | 12:34 PM
Czubaka's Avatar
It's vacuum line.
Old Oct 16, 2006 | 01:05 PM
06redMR's Avatar
do u guys have anything to say about the RS bar or is that just a pretty big waste of money
Old Oct 16, 2006 | 01:06 PM
Ultimate CC's Avatar
Looks like some nice pieces there but there seem to be some alternatives to doing them that will have greater effect on your cars handling but if you want to do everything possible then these are a great option...
Old Oct 16, 2006 | 01:49 PM
06redMR's Avatar
ya im getting my car muellerized with either the buddy club or JIC coilovers, 25mm adj rear sway bar and swapping the trailing arm bushings. im just gonna do all this works chassis stiffening before i take it in so i dont have to worry about doing up my suspension ever again, im gonna hit all in 1 shot, should be a crazy improvment . ill let you guys know how it goes
Old Oct 16, 2006 | 04:35 PM
mrfred's Avatar
Everything I've read is that it makes a small but positive difference. Seems worth it for the $35 cost.
Old Oct 16, 2006 | 05:22 PM
nils's Avatar
i use the croxx 2 plate... it works (no pun intended).
n
Old Oct 17, 2006 | 01:21 PM
Boosted GP's Avatar
I did the cut out myself, the rubber is "U" shaped rubber edging (for lining the edging of steel sheets etc). Didn't come with the rubber, got it from the local hardware store.
I'll take a pic of it and post it so you can get a better idea of the profile.
Cut out is bg so I can adjust the coilovers dampning.
Mike
ej257gd
45
Aug 1, 2008 10:33 PM
DanJ
21
Dec 21, 2007 08:07 PM
Jamie@WORKS
Lancer Ralliart Vendor Classifieds
40
Oct 14, 2005 02:28 PM
Jamie@WORKS
Evo 'For Sale' Suspension / Brakes / Handling
Feb 26, 2005 10:06 AM
Jamie@WORKS
Lancer Vendor Classifieds
19
Feb 7, 2005 11:09 AM
