bumpsteer correction kit????
Old Oct 22, 2006 | 09:46 AM
evo-boy's Avatar
how does this kit install, and where exactally does it go because there is nothing saying or showing where it goes or how it goes in.
any help would make a difference
Old Oct 22, 2006 | 10:10 AM
evo-boy's Avatar
really need some quick help
Old Oct 22, 2006 | 10:51 AM
Zeus's Avatar
You need a machine press and someone who knows how to use it... or someone really ingenious to dream up another method.
Old Oct 22, 2006 | 10:56 AM
Zeus's Avatar
BTW average Joe domestic mechanic's shop will generally butcher the job as they are not a customed to working with aluminum.
Old Oct 22, 2006 | 10:59 AM
evo-boy's Avatar
kinda figured i would need a press....
Old Oct 22, 2006 | 11:04 AM
Pure Playaer's Avatar
dude dont double post.. just bump ur old post.. noob
Old Oct 22, 2006 | 11:09 AM
evo-boy's Avatar
thanks for the above post for helping me to install my bumpsteer kit, thanks without you i dont know what i could have done
i love you trying to help, people like you are the reason stuff never gets done, thanks for your bs comments and my wasted time.....
Old Oct 22, 2006 | 12:48 PM
tsi90awd's Avatar
If you are writing about the Whiteline kit, it installs on the inboard side of the toe control arm on the rear suspension. You press out the old polymer bushing, press in the new one, and install the eccentrically drilled metal cylinder in the new bushing with the eccentric hole down. Essentially, this just lowers the inboard mounting point for the arm by 5 mm or so.
Look up Whiteline's home page. They have installation instructions somewhere there. Or, at least they were there a few weeks ago.
I installed this kit a few weeks ago. I was able to use a big bench vise and a couple of big sockets to press the old one out and put the new one in. Pretty easy, but YMMV.
You HAVE to have the suspension aligned afterwords. Make sure you tell the tech that the eccentric is there. If they screw up the placement, they can increase the bumpsteer, or make it impossible to adjust the toe. Ask me how I know!
Old Oct 22, 2006 | 12:49 PM
GTWORX.com's Avatar
I uploaded the directions.....they should have come with them. I apologize for that!
http://filebox.vt.edu/users/sekellic...278_KCA388.pdf
Returned your PM as well
- Andrew
Old Oct 22, 2006 | 12:52 PM
boostedwrx's Avatar
I just had the alignment shop do my kit when they aligned it after I did my Swift install. It only took them about 20 minutes. Youll need an alignment after you install them anyways...
Methodical4u
18
Nov 26, 2010 05:00 PM
leecavturbo
Jul 5, 2008 04:05 PM
lucas569
Jul 25, 2005 04:58 PM
sirloin1219
May 16, 2005 07:18 AM
Vtec1
Jun 3, 2003 11:41 PM
