Best handling spring for a MR
Originally Posted by h.funk
Jim. Transfurrrr is that how you spell it?? Have you ever learned about weight ratio??? Just stop you ant no Warrtalon....
Originally Posted by Mike01gsr
Praise the Lord Andrew...lol What is the E.T.A. on these before next spring?
If so I'll wait. Let me know.
- Andrew
P.S. - if you think the stock car is corner balanced from the factory with scales, then well.......um, no, it's just not. I'm not really sure what h.funk is getting at. If he could be a little more specific about what he's saying about weight transfer and weight ratio's, maybe I could help.
Originally Posted by Spinsall4
when u guys talk about the swifts are u talking about the MR specifc springs or the regular ones?
- Andrew
h, go drive around your worse then stock handling car on your tien ***. Nobody is going to take anything you say seriously knowing you run riced out coil's that have been proven by Robi to handle worse then stock. They work on Civic's, that's it.
Robi has proven Espelir GT's to handle 3% better then stock, with a lower more aggresive stance, and no sacrifice for drivability over stock. This is why he offers these springs in his basic suspension package. Robi is by far, the top chassis tuner in the Evo community.
Huh?
best handling springs? Springs are for show. You need to get coils to have the best handling car...
h.funk can't get more specific because he has no idea what he's talking about. He just keeps throwing suspension terms out there to sound like he knows his stuff; which he odviously doesn't.
Thats some good news to hear, has Robi seen any problems with the Bilsteins when paried with the Espelir GT's??
Just do the springs for now, and start putting money aside for a good set of KW's or Ohlins, for 30k down the road...
They must be the ACD's, seeing as the Espelir GT's have the stiffest spring rates out of all springs offered for the Evo. https://www.evolutionm.net/forums/sh...ad.php?t=66296
Though i have heard they ride smoother than stock...
Yeah, i think he said you can expect them to start showing significant wear around 30,000 miles. But what aftermarket suspension doesn't show wear around 30k? Even if you go coilovers, you will likely have to rebuild them in 30k also...
Well dude you must have alot of money, cause 300 and 1500 are in two ball parks. I have found the springs as low as 269 shipped. The cheapest I can find the coilovers I would want is about 1700-1800. Atleast to me that's a big difference.
