Best handling spring for a MR
Old Dec 17, 2006 | 04:25 PM
  #46
91TB78's Avatar
Not too mention you can resell the springs.
ALWAYS get an alignment after any suspension adjustment where height, camber or toe are affected.
Old Dec 17, 2006 | 05:24 PM
  #47
Jordanz3's Avatar
ok..so out of those three springs, swift , Espelier, work ..which one has the best looking drop
Old Dec 17, 2006 | 08:39 PM
  #48
GTWORX.com's Avatar
That is completely up to you! Both look good.
Check out the member gallery.
- Andrew
Old Dec 18, 2006 | 10:04 AM
  #49
KOEvo's Avatar
Espelir has the lowest drop out of the 3, if that is what you are asking...
Old Jan 2, 2007 | 03:46 PM
  #50
tirbolag9's Avatar
swifts have a decent drop...almost an inch all around. its not too low. the ride isn't that harsh but you can tell when on the streets. once you start to track you evo more often, then go with coilovers.
i'm satisfied with swift sport mach (MR specific). oh yeh, you don't even have to cut the bump stops!
for alignment, i went with -1 camber all corners and 0/toe all corners. at 12k miles, i had considerable tire wear with bad settings from the factory. i wanted to with -2 camber in the front, but wanted to save my tires.
astral
17
Jan 14, 2017 06:24 AM
Deano_Engineer_
Nov 7, 2016 04:31 PM
ANU Nick
Aug 9, 2013 06:42 AM
GreenAWD
16
Jan 26, 2011 01:33 PM
Boost3dxEvO
22
Dec 14, 2007 01:25 AM
