Robi Visit to Chicago
1. Lazyfong
2. goforwand
3. lexat20
4. WhiteEvo05 (KWv3 Club Sports 7k/8k, roll center kit, rear bump steer kit, trailing arm bushings, rear sway bar, front sway bar links (if out yet), align, corner weight...I think that's it )
5. Tristar Racing (alignment only)
Removing from Chicago list, but may have to re-add if Omaha falls through.
2. goforwand
3. lexat20
Robi,
I sent you an email about a week ago concerning my setup. Did you get it?
Jsimpson@thermo-pak.com
Robi,
Im new in the suspension side of the Evo. I only have a rear sway and rear strut bar. I may be interested when you come. Any suggestions on what you do? It is mainly a streetcar and will be brought to a road course once or twice during the season. Let me know...Thx!
1. Lazyfong
2. goforwand-Realignment (finally
), Clubsport road test and adjustment; adding front roll center correction, and might as well install the GT Spec trunk cage at the same time...
3. lexat20
), Clubsport road test and adjustment; adding front roll center correction, and might as well install the GT Spec trunk cage at the same time...3. lexat20
1. Lazyfong
2. goforwand-Realignment (finally ), Clubsport road test and adjustment; adding front roll center correction, and might as well install the GT Spec trunk cage at the same time...
3. lexat20
6.nood1es springs/alignment*depending on date*
depending on date, count me in for springs/install and alignment.
3. lexat20
1. Lazyfong
3. lexat20
7. Ookami (ground control front camber plates, rear bumpsteer kit, rear trailing arm bushings, install, cornerweight, laser align KWv3s 7k/8k) [deposit sent]
Any information on where this is going to be held in Chicago and install times?
3. lexat20
1. Lazyfong
3. lexat20
8. Ballistic speed (respring for 275 hoosiers r6s, front driver side shock rebuild, realign for 275 r6s and drop rear + cornerweighting)
3. lexat20
1. Lazyfong
3. lexat20
9. inco9nito99 - corner weight/align, change springs front to rear, rear trailing arm bushing, rear bump steer kit.
3. lexat20
