Robi Visit to Chicago
Old Dec 31, 2006 | 11:07 AM
  #61
prostcj's Avatar
I may be very interested in this. Any dates been firmed up?
Old Jan 1, 2007 | 03:36 PM
  #62
Tristar's Avatar
Second week of April.
Old Jan 4, 2007 | 09:41 AM
  #63
boomn29's Avatar
Originally Posted by robi
first...the car COMES with coilovers...(non-adjustable with mildly retarded damping curves imo)...the Bilsteins improve on this damping issue but are still non-adjustable for cornerweighting (10 tenths I know)...aftermarket springs do two things, they get the car lower and increase the spring rate...BOTH important for reducing the body roll and improving front grip...mainly due to camber curve preservation....on the outside front tire, but also the increased weight transfer through heavier springs.....as you track your car more and add WHP bigger stickier tires will be on the wish list.....and you will RUN OUT OF SPRING RATE with ANY aftermarket springs (including mine soon to market.....)since you can't "improve" the roll timing through adjusting the low speed damping sections (read KW Varient 3's here) ...you are stuck. It seems through testing that 255 "r"s like the Nitto Nto1 and Toyo RA1 are just over this limit and "DOT slicks" get there at 235's...(just under)
.......................The Basic is just that get the car ready to track with the ride height "close" to what you will be using and get the car rotating like a balanced car should..ON A BUDGET.....on cold days you will have better grip than an over sprung/ over dampened coilover car on hot days slightly less...as you run your self out of spring with the improved grip as the r compounds get to temp..BUT the car will have all the improvements nessisary so WHEN they add ADJUSTABLE coilovers (remeber the Evo has coilovers right from the factory)..they get the most out of them...
How would you rate the MR bilsteins with different springs in them as an option? I see a lot of people buy these used and put in different springs as their setup.
Old Jan 4, 2007 | 08:58 PM
  #64
91TB78's Avatar
1. Lazyfong
2. goforwand
3. boomn29
4. lexat20
5. Tristar Racing
6.
7.
8.
9.
10
__________________
Old Jan 4, 2007 | 09:02 PM
  #65
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Jump on this guys! You will not be dissapointed
Old Jan 4, 2007 | 11:06 PM
  #66
robi's Avatar
Better street ride, slightly slower side to side, better grip on slicker surfaces,
Old Jan 6, 2007 | 07:50 AM
  #67
V.8MR's Avatar
I may be interested, but i am curious about the pricing and services that will be offered. I have buddyclubs racing spec and am getting new rims and tires and i would like a good corner balancing/ride height adjustment and a good advisor on alignments!?
Old Jan 6, 2007 | 07:54 AM
  #68
V.8MR's Avatar
Oh boy im sorry. I read through the thread a little better. I see your pricing structure.
Old Jan 6, 2007 | 05:26 PM
  #69
WarmPepsi's Avatar
+rep for boss-man.
can't be happier with the service and capabilities my car has aquired.
Old Jan 29, 2007 | 02:20 PM
  #70
boomn29's Avatar
Is the tentative date still April? Not sure who's organizing the facility for this?
I just wanted to bump this since I put together a listing of midwest road-race events recently in the Midwest forum.
https://www.evolutionm.net/forums/sh...71#post3904571
Old Jan 29, 2007 | 02:59 PM
  #71
cfdfireman1's Avatar
Sure is
Talked to Robert today first or second weekend in April.
Old Feb 28, 2007 | 01:36 PM
  #72
speedomodel's Avatar
Robi: if you have time to spare on your way to Chicago, there's an open-track event at MAM on April 7th and 8th.
Old Feb 28, 2007 | 03:28 PM
  #73
DaWorstPlaya's Avatar
Also this time around there may be more Nebraska EVO owners looking to do installs and alignments.
DaWorstPlaya
Ookami
Nubby (aka WheelGap)
Possibly some other members ...
Old Feb 28, 2007 | 05:54 PM
  #74
Tristar's Avatar
I was contacted about this Chicago trip by a member in Nebraska. Let me say that right now I am currently in a job search, so I cannot give this visit the attention in needs for planning. Ill try to help when I can, but I think someone should take the lead on this to get it done.
Old Mar 1, 2007 | 10:45 AM
  #75
Ookami's Avatar
DaWorstPlaya
Ookami
Correct, I'm looking to have an install done, in Omaha is of course preferable, but I'm willing to drive.
