Installing used tires
I bought a set of takeoffs (stock advans). I know that we when we rotate tires they are supposed to go front to back only. But if I am putting on used tires, how do I know which of his tires were on his right or left side? Does it matter at this point? If I mix and match, isn't that equivalent to rotating tires across left and right?
You just would like to end-up with 2 having the rotation arrow going one way (looking from the outside of the wheel) and 2 with the arrow going the other way. Also, these cars usually kill the inside of the tire 1st, mount with the most rumber in. The rotation directional correctness will be most important in the wet...
JW
JW
Put them on so the most worn part is on the outside now. In most cases the inside wears first so you would be "Flipping" them. Stock A046 tires are directional only no inside outside.
