Spring Install
Old Feb 22, 2007 | 03:45 PM
1BlackEvo9's Avatar
Spring Install
Getting ready to install my springs and I heard that you need a special wrench to remove the springs from the front struts because the nut is recessed down on the shaft, has anyone done this without this special tool? If I do need this tool what is the proper name for it so I can go pick one up.
Old Feb 22, 2007 | 10:40 PM
evo150's Avatar
its called a spring compressor. go to autozone,advanced auto, etc. and for 20 bucks you can get it. its best to use one or when you take that specific bolt off. ill post some pics and a link for you to follow for the install.
Old Feb 22, 2007 | 10:45 PM
evo150's Avatar
pic of spring compressor, and here is a link to installing your springs http://evomoto.com/tech_info.php?tPa...1736629e007905
Old Feb 23, 2007 | 05:31 AM
1BlackEvo9's Avatar
No, I know you need to use a spring compressor to compress the spring. I am talking about the shaft nut on the strut. It is recessed down so you can't get a normal wrench on the shaft to keep the shaft from spinning when you go to losen the nut. I would normally use an impact gun and not worry about holding the shaft but Mitsubishi suggests not using an impact gun for some reason.
Old Feb 23, 2007 | 06:28 AM
subaruwrx420's Avatar
I read the link provided but it doesn't say exactly what specialty tools to buy or where to get them. I'm also going to install Espelir GT springs in the very near future.
Bump for more information.
Old Feb 23, 2007 | 06:31 AM
16ggst's Avatar
https://www.evolutionm.net/forums/sh...ad.php?t=84013
is a write up on here.. doesnt seem to need anything out of the ordinary
trjx24's Avatar
bump for website.. i wanna bump it so i can find it again... haha
Old Feb 23, 2007 | 06:34 AM
Shammy's Avatar
I was thinking about buying a lowering springs for my evo instead of coilover. I heard you have to buy a rear sway bar so you won't loose your ride. Is that true?
Old Feb 23, 2007 | 07:42 AM
GTWORX.com's Avatar
You don't have to buy a rear sway bar when you get springs.
It helps the car handle better overall, but the car will still handle better with just springs. As long as they are good springs (Swift, Works, etc.)
- Andrew
Old Feb 23, 2007 | 07:49 AM
SPANKED's Avatar
I'm going to do the install also and read that you can loosen the bolt slightly before removing it from the car.
Old Feb 23, 2007 | 08:25 AM
GTWORX.com's Avatar
You shouldn't need to.
- Andrew
Old Feb 23, 2007 | 08:43 AM
Alright, looks like I'm going to proceed with the install without any specialty tools. It also seems like tightening the top nut on the strut is more damaging with an impact than removing it. In one of the threads it says to tighten to 33 lb/tr, so I can see how hitting with an impact might be a problem.
Thanks.
Old Feb 23, 2007 | 10:21 AM
evo150's Avatar
i just used a normal socket (dont remember the size). but be sure to loosen it some before loosening the bolts on the upper perch mount. follow the evomoto guide exactly and your install will come out perfect....at least mine did
Old Feb 23, 2007 | 10:38 AM
1BlackEvo9's Avatar
Thanks, That is what I will do..
Old Feb 23, 2007 | 10:46 AM
hondafan's Avatar
yeah, you just have to crack that top front strut nut loose while the car is still on the ground and it won't spin, just like the evomoto write-up. just use a deep socket.
