HOW TO: RSR Ti2000 springs into 03 Evolution
Old Jun 8, 2004 | 01:30 PM
M3lachsilber's Avatar
choad
Courtesy of Pro Street Online..
This how-to is based on a spring install of RSR Ti2000 Springs for a 2003 Mitsubishi Lancer Evolution.
Tools required
floor jack and 4 jack stands
spring compressor
socket wrench
breaker bar (long socket wrench without ratchet)
sockets: 12mm, 13mm, 14mm, 17mm, 19mm
wrenches: 12mm, 17mm, 19mm
flathead screwdriver
pliers
rubber mallet
Old Jun 8, 2004 | 01:31 PM
choad
General Steps:
Jack car up onto jack stands or lift
Remove wheels (19mm Socket)
Old Jun 8, 2004 | 01:32 PM
choad
This is what you will be working with in the front
Front
Remove the clip that holds the break line to the shock (12mm bolt) - Image below is the back of the shock
Old Jun 8, 2004 | 01:33 PM
choad
Remove the 2 bolts holding the shock to the hub (19mm)
Old Jun 8, 2004 | 01:35 PM
choad
Slowly push axle down and pop shock assembly out of hub
Remove the 3 bolts from top of strut tower in engine bay (14mm + socket)
Old Jun 8, 2004 | 01:36 PM
choad
Use a spring compressor to compress the spring.
Undo the top nut on the shock, and remove the assembly.
Cut the bump stop in half
Replace all parts, and place new spring into the shock. Tighten everything down.
choad
Reverse these steps to put the assembly back in.
Repeat these steps on the other side
Old Jun 8, 2004 | 01:37 PM
choad
Rear
Remove trunk liner (Push in retaining clips to unlatch them)
Remove bolt holding shock to control arm
Remove bolt holding control arm to hub
Remove the two bolts in the trunk to release the shock and spring
Repeat steps 20-25 on other side
Old Jun 8, 2004 | 01:39 PM
choad
RSR Ti2000 Springs Installed. The best part is, these springs will never sag!
Click here to order RSR Ti2000 Titanium Springs
Old Jun 8, 2004 | 01:41 PM
choad
Discuss thread HERE.
anthonypazsd
135
Apr 2, 2026 12:56 PM
Jaraxle
Evo X How Tos / Installations
Apr 6, 2022 05:39 AM
halfnhalf83
31
Oct 7, 2015 08:23 PM
toolmanblink182
Lancer How Tos / Installations
25
Jul 29, 2011 07:23 AM
ProStreetOnline
14
Mar 20, 2007 08:00 PM
