Brake install question!!!
Hello everyone. I tried doing several searches on this website but didn't find quite what I was looking for. Im getting ready to do a brake pad swap on my MR and was wondering what methods you guys used to push the pistons back into the calipers?? I have the Mitsubishi Service manual and was going to try and purchase the tool they had in the manual from Mitsu. But they told me I couldn't purchase it from them. So.....any suggestions on what to use or where to buy that tool??? Thanks.
You don't really need any special tool. Put a big screwdriver between the pad and brake rotor and *gently* pry the pad so it pushes the pistons back in the caliper. You can use this method to push the pads completely back or to just loosen them up a bit so you can pull the old pads out. Once they are out, you can just use finger pressure to move the pistons back. You will have to alternate between the pistons because when you push one back the other(s) will tend to come out again a bit. It's easy.
+1 ... use your old pad like a lever to push both pistons on 1 side at the same time. Also make sure you open your brake fluid reservoir so that the fluid has somewhere to go. You may need to suck out some of the brakefluid from the reservoir before it overflows.
bryonboals
For Sale - Miscellaneous Automotive
10
Sep 23, 2012 08:58 AM
