yet another 17x9 RPF1 question
Old Apr 9, 2007 | 02:09 PM
UCB's Avatar
UCB
I know for the 17x9 +35 RPF1 you need to run a 15mm spacer, more like 17-19mm spacer to be safe to clear the brakes in the front.
Im really weary to run such larger spacers+extended lugs. Anyone try out the 17x9 +22 RPF1 in the front? Any spacer (if at all) required to get these to fit, or is the hub/spoke spacing similar to that of the +35?
Old Apr 11, 2007 | 06:02 PM
Td5turbo's Avatar
they have a pretty high disk...might work
Old Jun 18, 2007 | 10:33 AM
SeanJhn9's Avatar
i was told that you only needed a 10mm spacer for the 17x9 +35, but found out the hard way and couldnt use my R comps this weekend becuase of this, it still wouldnt clear the calipers at 15mm, so i'm assuming to run it safely you need to run 20mm
Old Jun 18, 2007 | 11:26 AM
lexat20's Avatar
step up to the 9.5 wide w/ 38et and you need a 20mm spacer for the front/nothing for the back
Old Jun 18, 2007 | 03:46 PM
homiusang's Avatar
You'll need to run a 20mm spacer for sure. I have the same set up.
ant_BLR
Apr 8, 2014 06:19 AM
tmaddox
15
Oct 14, 2013 12:22 AM
Gordian79
11
May 22, 2013 02:02 PM
Mishi9
21
Nov 21, 2010 03:59 PM
steve_evo
26
Jan 26, 2007 04:53 PM
