Coilover Install
Old Apr 15, 2007 | 04:29 PM
aspec04t's Avatar
Coilover Install
Hi,I just recently purchased an Evo IX, and I bought my self a set of megan coil overs. I used to have an RSX and i did all the installs of all of my suspicion stuff on that car. I was hoping someone could point me towards a how to install coil overs evo. I did some searching , however I couldnt find anything. Any help would be appreciated. Thanks
Old Apr 15, 2007 | 06:35 PM
t51splbb's Avatar
Here you go,right in the "how to" forum. They are not Megan coilovers,but the process is the same for both.
https://www.evolutionm.net/forums/sh...d.php?t=231828
Another thread that has good information on adjusting them along with install tips,pics and is Megan specific.
https://www.evolutionm.net/forums/sh...ilover+install
Old Apr 19, 2007 | 06:33 PM
MRinChrist's Avatar
Nothing to get intimidated by. Very easy to uninstall and install coils on the Evo. Have your car on jackstands and use your hydraulic jack to manipulate the suspension knuckle, if need be, once you have the coils in place and ready to bolt up. Of course an alignment will be necessary ASAP...Make sure your brake lines aren't going to rub on anything and that they are secure.
Old Apr 20, 2007 | 08:53 AM
19psi's Avatar
coilovers are easy as installing an exhaust but a bit more time consuming.
Go to www.evomoto.com and look under "installs".
There is a install for some springs but you an use that for reference.
It's very detailed and you should be able to do it in about 3 hours with
some break time in between.
Old Nov 3, 2007 | 10:31 PM
jerchi's Avatar
Does anybody know the proper torque specs for the suspension bolts needed to install the coilovers? There's a ton of writeup but no torque specs.
Old Nov 4, 2007 | 06:47 AM
CrackerJackToy's Avatar
Im a small guy, 160 lbs and I have never worked on suspension in my life. Everything is straight forward. It took me a total of 3 hours to do everything and that included clean up time. Good luck.
BoostNY
Feb 20, 2017 09:46 AM
evoxisking
Sep 2, 2015 02:11 AM
Hartless93
Jul 24, 2014 04:09 PM
evodude32
16
May 8, 2013 08:55 PM
j14mp
May 30, 2007 02:56 PM
