Widetrack front end?
Old May 10, 2007 | 09:22 AM
  #31
DaWorstPlaya's Avatar
Originally Posted by Boltz.
Anyone have opinions on the how this could cause extra stress on suspension components and what effect that would have overall?
Thx
If done to the front:
1st it will mess with you scrub radius if you go too far.
2nd it will put higher stress on your wheel bearings causing them to wear out quicker/prematurely.
3rd since the wheel sticks out further it applies more force to the springs and shocks due to the larger lever effect.
The plus side is, it increases front grip.
Old Aug 29, 2007 | 11:03 PM
  #32
2hot2handle's Avatar
Back from the dead.....is this really true?
Old Jan 7, 2008 | 10:09 AM
  #33
aznj's Avatar
re-reviving a dead thread, but...
if the chargespeed guys do it, it can't be all that bad right?
Old Jan 7, 2008 | 06:17 PM
  #34
Noob4life's Avatar
wrong. doing something just because someone else does it isn't exactly the best idea. asking why it's done goes a whole lot further.
Old Jan 7, 2008 | 07:25 PM
  #35
aznj's Avatar
did i say that i was going to do it because they did? no
i just stated that they do it, so there must be some reasoning behind it. obviously just a way out of getting a wider track without getting new wheels
Old Jan 7, 2008 | 09:38 PM
  #36
lucky13evo's Avatar
I run +15 all around on my 9 i have done about 5 track events and have about 12000 miles on the car the rims have been on since day one.The car understeered terribly at first but after some suspension tinkering i was able to kill the understeer iam running -3.0 camber up front and -2.0 in back kw v3 robispec plus a27mm rear sway bar car handles great now and barely under steers at all. i imagine that if i were to put a higher offset wheel in the back th car would probably rotate a little better but iam preety happy right now and car looks great. Pretty soon i will probably buy arim set up that has etter offsets like +15 up front and +29 in the rear . Just wanted to put my input with crazy offsets.[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
here is some pics
Old Jan 7, 2008 | 10:26 PM
  #37
gone2pimp's Avatar
So did anyone ended up trying the 20mm spacers on stock rims? And if so how does it drive and look
Old Jan 10, 2008 | 09:44 AM
  #38
aznj's Avatar
oh yea, and here's the HKS all-carbon evo... i think i'd trust their judgement
Old Jan 10, 2008 | 05:52 PM
  #39
Noob4life's Avatar
Do whatever you like, if you think your car is anywhere close in terms of build or purpose to the HKS Evo.
Old Feb 21, 2008 | 11:48 PM
  #40
dannys EVO IX's Avatar
anyone?
Old Feb 22, 2008 | 12:02 AM
  #41
evobeatsti's Avatar
i am going to run a wider front track by running a +15 in the front and a +34 in the back.
Old Feb 22, 2008 | 12:08 AM
  #42
evobeatsti's Avatar
i ran a 25mm spacer with stock wheels and it worked but that was on stock suspension and snow tires, a little more relevant, i ran a 25mm up front and a 10mm in the back on some 17x8.5 +30 ce28s and it worked fine
Old Feb 22, 2008 | 03:08 AM
  #43
robi's Avatar
+18 front with +38 rear 10" wide all the way around...about the limit of the stock body with 275 tires (17" diameter)
Old Feb 24, 2008 | 05:43 PM
  #44
4cdndctn's Avatar
Glad you chimed in Robi - I'll be seeing you tomorrow with my new setup which includes the H&R spacers provided by Kyle.
Rest up!
Jonno99
Jul 18, 2017 11:43 PM
cudaman07
11
Sep 22, 2009 01:38 PM
TVA
For Sale - Cars For Sale
18
Jan 8, 2009 10:17 AM
Silver06evo9mr
56
May 21, 2007 05:10 PM
black03oz
26
Oct 25, 2006 07:37 PM
