caster help
Old Jun 18, 2007 | 07:16 AM
bluevo8urV8's Avatar
caster help
i'm trying to align my evo 8. everything is set right but the caster. its off like .3 degrees . anyone know how to set caster on our cars?
Old Jun 18, 2007 | 07:19 AM
Curt@MrLed's Avatar
Former Vendor
its not adjustable, unless you buy castor camber plates.
Old Jun 18, 2007 | 10:13 AM
DaWorstPlaya's Avatar
You need camber/caster plates to adjust caster. I happen to be selling some Ground Control Camber/Caster plates ...
Old Jul 7, 2007 | 03:48 PM
cfdfireman1's Avatar
Caster is adjustable on the evo you need the cradle adjusted.
Old Jul 9, 2007 | 01:43 PM
500whp.com's Avatar
From what i know Stock suspension can't adjust caster, and so are most of the coilovers out there, but i might be wrong.
Old Jul 10, 2007 | 08:24 PM
chrisw's Avatar
the caster is off to accomidate the crown in the road so the car will track straighter on a public road.
As others have said, camber caster plates are the only way (that I know of) to adjust caster.
Old Jul 10, 2007 | 08:32 PM
JohnBradley's Avatar
.3 is nothing, some cross caster is desirable as pointed out for road crown and whats called 'isolation' in the suspension.
Factory spec for some vehicles....coughChevyTruckcough....is about 1* of cross caster. Secondly is it off or has it been awhile since the alignment rack was calibrated, is rack itself level, were the turnplates in good repair, was the tech doing the sweep correctly.
Does the car drift? If not dont worry about it.
yarlasasi
Feb 25, 2015 01:06 PM
nudge120
Apr 15, 2012 11:33 PM
nrgizeman
Apr 4, 2009 02:17 PM
EVOlutionary
Jan 9, 2008 07:04 PM
EVO8speed
Dec 30, 2003 08:24 PM
