NOOB ? Breaks noise (click)
Old Jul 2, 2007 | 09:33 PM
sette3's Avatar
Question NOOB ? Breaks noise (click)
Is it ok to hear A Clicking noise when i press the breaks (not from the pedal but from the rear calipers ) ????
Old Jul 3, 2007 | 12:26 PM
evo150's Avatar
is this only happening when you reverse? or when moving forward and reverse? have you changed your brake pads lately? there are some pads that are a mm or 2 smaller than the stock size and shift in the rear caliper (this usually only happens after the car has been sitting overnight or a long period of time and reverse out of your parking spot).
Old Jul 3, 2007 | 12:43 PM
hondafan's Avatar
it happens on mine too. yeah, mostly in reverse or very slow speeds going forward like in traffic. i have hawk hps pads. must be the pads, didn't do it until i installed them.
Old Jul 3, 2007 | 12:48 PM
tvbf1's Avatar
I'm experiencing the same event as well. Like evo150 said, it only happens after it sits for awhile or at low speed. I have the porterville pads from Gruppe-s, and if evo150 said is correct about the pad being a mm or 2 smaller then the stock Brembo. Then it's not really a big deal then right?
Old Jul 3, 2007 | 02:39 PM
MasterNater's Avatar
I've been experiencing the same issue ever since I put on a set of Hawk HPS pads. The "click" only happens right when I push on the brake pedal after driving a short distance. Once it occurs, I can press the pedal repeatedly, and it never happens again. Drive a short distance, press the pedal, and it clicks again. It just sounds like the pads shifting in the caliper.
Old Jul 4, 2007 | 10:30 PM
evo150's Avatar
did you peel the metal shim off of the stock pad and reuse them on the new pads?
Old Jul 6, 2007 | 04:11 AM
ForgivenxSoulja's Avatar
Hmm weird ive never herd anything like that
OTRMercuryG
Jun 30, 2016 06:50 AM
CarPhoto.net
22
Jun 27, 2016 06:58 PM
C_LosEvo
10
Oct 28, 2011 08:57 AM
turbotekray
Sep 26, 2010 02:47 PM
AhmadHasib
Mar 28, 2007 05:11 PM
