Brakes Squeak
Brakes Squeak
Hey my brakes started to squeak last night. I have 1200 miles and I don't use the brakes like a granny. Some people told me its because of the dust(theres allot of dust where I live). My dad told me to do some panic stops and it should clear it out. Will that fix it? Anyone else have this problem??
Yeah, mine are squeaking, but only when i put a certain amount of pressure on them. It usually doesn't bother me. Also, sometimes when i slow to a stop with the clutch in, the engine makes a funny whooping noise(very quiet) but it sounds alot like police sirens......which scares me everytime hahaha.
I know the noise is normal, but its to bad it sounds like a cop.
When the brakes get hot, it will make some noise when you slow down and apply low pedal pressure. It is normal for these brake pads. And as long as you don't brake hard for awhile and let the brakes cool down, the noise will be gone. If you don't like the noise, just wash off the brake dust every couple of days. This should help.
I posted this on another thread.....
I found the fix to the brakes squealing. I do not have to clean my car very often with living in sunny Phoenix heh. Each week I give it a California duster treament and some Meguiars Detail Spray. I spray the wheels down with water and wheel cleaner and dry them down with a towel. So I began to notice my brakes squealing more and more, right. So I say WTF, I had noticed everytime I gave it a full car wash with the power hose, the squealing would stop for a week, so I began to really spray the wheels down each week, getting inside near the calipers real good. Bam, problem solved. No more squeak if you clean all the brake dust out with a good hosing of water and wheel cleaner. Thought I would pass it on.
Mine squeak like a bus after I change to AP Lockheed pads. It also generates a lot of brake dust, and wear the disc faster. But I think the brake is a very important mod, and I can't wait for the disc to wear out so I can buy better one.
squeak
i put in new brembo rotors on my front right tire and used the same brake pads. i drove the car around to see how it feels and the brake pads keep rubbing against the rotors and wont stop at all unless im not moving.. i need help!!!
Mag00n
68
Dec 23, 2013 03:29 AM
mitsuevodriver
Feb 22, 2010 01:50 AM
LooneyToon
May 11, 2009 05:25 AM
CrackerJackToy
15
Nov 29, 2007 03:46 PM
Seems kinda strange, but I would rather it only squeal in reverse than during normal driving.
