The Official Wide Tire Thread
Old Jul 2, 2013 | 05:48 PM
  #481
heel2toe's Avatar
^You are going to have a hell of a time trying to fit those wheels under the body of your car assuming its a stock body. That low of an offset is not going to play nicely with your fenders...
Old Jul 2, 2013 | 06:06 PM
  #482
project8's Avatar
18x10.5+12offset
Do you have any advice to what amount of fender work its gonna take to get this to fit?
Old Jul 2, 2013 | 07:09 PM
  #483
nollij's Avatar
sawz-all and widebody or someone who can reallllllly pull a fender (>1")
Old Jul 3, 2013 | 07:11 AM
  #484
griceiv's Avatar
18x10.5+12offset with a 285 30 tire size, can this set up work? Or not. Can someone give me a feedback on this please Thanks guys!!!
bust out the sawzall and maybe. most people would say no.
Old Jul 3, 2013 | 06:12 PM
  #485
Heres some perspective. I run a relatively aggressive set-up (275/40/17 +29)
My simple set-up required a roll, porta pwr pull, bumper bolt relocate, rear splash guard removal, Lower rear bumper cover adjusted outboard (No rub, stock camber, track ready)
Your +12 proposal w/the 285 is 1.2" further outboard
Old Aug 11, 2013 | 08:14 PM
  #486
khmerpimpin's Avatar
For those that run the Perrin PSRS do you go with the offset version, or regular?
Old Aug 12, 2013 | 05:52 AM
  #487
chu's Avatar
chu
Offset version if you want caster.
Old Aug 12, 2013 | 08:42 AM
  #488
Dallas J's Avatar
Veteran: Army
Offset, it also helps fit bigger tires clearing the back of the fender well. Though as ASP has shown, its not absolutely needed.
Old Aug 29, 2013 | 08:52 AM
  #489
Vindots's Avatar
Guys from aussie here sorry for chiming in as a newbie,
I got a set of svnr 18x10 +20 front and +30 rear
Looking for atleast 265/35 size tyres, anything i need to do aside from rolling guard?
Old Aug 29, 2013 | 09:37 AM
  #490
Dallas J's Avatar
Veteran: Army
With 265s, rears should work with a roll and some camber. Front may need a spacer to get clearance just right but that depends on fender roll and suspension.
Old Aug 31, 2013 | 10:32 PM
  #491
Grimgrak's Avatar
Lets just say the amount of work to make it work, provided it doesn't crack/tear, will cost more than the price of your rims.
Old Sep 1, 2013 | 05:31 AM
  #492
Very doable. I just ran your numbers on the calc. You will need the full rear treatment using stock camber (roll, pull, bumper bolt). Dont roll-in out of spec camber to make it work, but hey, thats just me
You will see some front fender issues possibly if you set the ride height low. May need the fender extender kit
Old Sep 1, 2013 | 08:19 PM
  #493
V.8MR's Avatar
Im currently running:
Volk CE28
F/18x10.5 +18 Has 10mm Ichiba hub-centric spacers as well.
R/18x9.5 +28
Yoko Advan a048 265 @ all four.
I just realized I last posted in this thread on Sep 5, 2008, 10:22 AM... Setup has not changed much besides body work and evodave fender mod.
Was trying to imitate the Cyber Evo at the time of purchase. I like the idea of promoting rotation and thought the added grip up front would also help w/under-steer.
Had to roll and pull the rears, plus some grinding...
Fronts have evodaves fender mod. Still have the liners in as I don't like the idea of sandblasting the inside of by fenders. Depending on how this works out I may have to pull them back out once at the track.
Rubs on full lock mostly. No problem normal driving or bumps etc. Rear does not rub at all. Front rubs on inside of the liner where the engine bay is. Also rubs on the side skirts. Have not tracked it yet so we shall see. Need to get some brake work done before she is track worthy again. I will have to investigate the PSRS from Perrin to see if I can get rubbing out of the equation on high load situations like track days.
Sans fender:
Old Sep 2, 2013 | 06:10 AM
  #494
Vindots's Avatar
Hi mate, thanks for the tip. Im just afraid to roll because i dont want the dent on the rear panel caused by pulling, any tips for the dent not to happen.. Ive been doing fender rolling before but i noticed that our evo has a tendency to dent when rear fender panels are pulled.
Old Sep 2, 2013 | 10:21 AM
  #495
I know, there is no free lunch Ive got the crease as well
