The Official Wide Tire Thread
Old Apr 10, 2013 | 10:04 PM
  #436
RJones's Avatar
Originally Posted by griceiv
double wide body kit?
Depending on the offset it'll fit with just a standard widebody. I run 18x11 +5 up front with just the fender spacer kit, and I know 10.5 +15 will easily fit in the rear with a Voltex rear fender, so 11" shouldn't be much harder.
Old Apr 12, 2013 | 10:02 PM
  #437
Grimgrak's Avatar
Do you have the perrin psrs? My 245/40/18 snow tires hit the front rear as well. This fixed it for me.
Originally Posted by Meathooker
front:
fender lines are out but they did run on the back with the taller tire. also spaced the front fender out a bit (.375" maybe) but there is a lot of room up there.
Back:
rolled flat and pulled. we used a porta power and some serious bars with uhmw for protection to get it as far as we did. one side no rubbing anywhere, but the othet has a slight rubbing on the tire. im on ohlins flag COs and they are pretty low ride height so that doesnt help.
even three wheeling im not rubbing other than slightly on the outside of one rear tire:
Old Apr 14, 2013 | 07:07 PM
  #438
Meathooker's Avatar
No. I run asp so I can't. Thinking of going sm so I might do it then.
Old May 19, 2013 | 07:13 PM
  #439
EvilTechnology's Avatar
Just ordered Federal 285/30 18" to go on my Nt03 40et offset. Right now I'm running 265/35 18 Hankook Evo 12's with a 22.5mm front spacer and no rear spacer. No rubbing.
Should I order some 5mm spacers for the rear?
Old May 19, 2013 | 08:24 PM
  #440
Blue91lx's Avatar
Very excited to see how this goes for you. I have 265/35s on my +27 NT03s, and my end goal once I kill these tires is to fit 275s.
I'm thinking they'll fit somewhat close to the 18x10.5s pictured above. Has anyone fit 275s on an 18x9.5 +27 or something close?
Old May 19, 2013 | 09:04 PM
  #441
I'm going to roll the rears and slap on an Evo Dave front kit, but thinking I might need some small spacers in the rear. Now I have about 1/2" clearance between the tires and trailing arm.
Old Jun 3, 2013 | 08:32 AM
  #442
Kaizer's Avatar
Originally Posted by XcreatonX
Just got my tires mounted up today. I still have to adjust ride height, add camber and roll and pull the fenders. The specs on my setup is.
RPF1 18x10 +38
285/30/18 Star Spec ZII
front 18mm spacer
rear 6mm spacer
Strangely enough, the 18mm does not work for me! It will not clear the calipers.... Sucks!
Old Jun 3, 2013 | 08:46 AM
  #443
heel2toe's Avatar
^What wheels are you using and what size are they?
Old Jun 3, 2013 | 09:15 AM
  #444
Kaizer's Avatar
Work XD-9's 18x10 +38...
295/30/18 Toyo R888's....
Old Jun 6, 2013 | 10:13 AM
  #445
aporambo's Avatar
front:
Back:
Impressive work getting that combo of wheel/tire to fit and function during some autox laps. I need to make an appointment to get my rears pulled a bit more out for my current setup.
Old Jun 6, 2013 | 10:20 AM
  #446
evobros's Avatar
Lets see some 375s lol Jp guys. S*** would be dope tho.
Old Jun 6, 2013 | 10:47 PM
  #447
XcreatonX's Avatar
That is strange. I have a good amount of clearance. I did space my front fenders and rolled and pulled the rears. Hopefully it is enough to avoid any issues. I will find out this weekend when I race.
Meathooker what spring rates are you running? Do you have a picture of your car sitting?
Old Jun 9, 2013 | 09:30 AM
  #448
Kaizer's Avatar
Just getting around clearing everything for wheels to fit, I think it has something to do with the spoke design of the Work XD9's...seems to need an additional 3 to 4mm (Eye measurement) to clear the calipers....
Old Jun 10, 2013 | 10:41 AM
  #449
Kaizer's Avatar
With the RSPS, the tires do clear the skirt but hit the rear of the bumper, time for some caster plates! Still having issues with the caliper clearance......
Shaving the brembo's....not an option for some additional clearance? If having to go with a wider spacer, the tires will be sticking out too much for my taste....I will get some pics up shortly....
Old Jun 11, 2013 | 06:20 AM
  #450
Kaizer's Avatar
These are the pics...the wheels are installed with the 18mm spacers and the calipers of the car. It does have the fender mod kit on at the moment...Car is lowered but not aligned!
