struts vs. coilovers
Old Dec 23, 2007, 06:06 AM
  #31
sleeper3's Avatar
Originally Posted by GTWORX.com
1. Ultimate set-up: Ohlins fixed perch adjustable dampers with either Swift or our own GTWorx springs
2. Awesome: Bilstein HD dampers (or EVO MR Bilsteins) with Swift or GTWorx springs
3. Good: stock EVO dampers with Swift or GTWorx springs.
Both the Swifts and our GTWorx springs are great. The Swifts lower the car a little more then ours, but are a little softer. Pick which ride height you like better.
You can add a rear swaybar and some Whiteline bushings if you like, but for just a DD, you don't really need to.
- Andrew
just my opinion....
Where would you rank the Bilstein PSS9 on your list?
Old Dec 24, 2007, 08:36 AM
  #32
GTWORX.com's Avatar
Tough call. Kinda near 1, but it's a very different feel. Very comfortable, but still feel like coilovers. Really really good coilovers with great valivng though.
- Andrew
Old Dec 25, 2007, 08:12 AM
  #33
sleeper3's Avatar
- Andrew
Cool, right now they are the top pick on my list based on the research I've done. If my budget allows next year I'm getting those. Separate adjustment of compression and rebound in particular are key for me.
Old Dec 26, 2007, 08:24 AM
  #34
GTWORX.com's Avatar
In that case, KW's would be worth looking into. A true 2 way for under 2k. The provided rates (9k/6k) aren't great though, custom rates are recommended.
- Andrew
Old Dec 26, 2007, 08:42 AM
  #35
littlebluegt's Avatar
- Andrew
What custom rates do you recommend for mostly DD, but the odd auto-X or track day (2 or 3 a year)?
Old Dec 26, 2007, 09:00 AM
  #36
sleeper3's Avatar
- Andrew
Wait...are you saying the PSS9 combine rebound and compression in one adjustment? If so that really sucks, if anything a single adjustment product should keep compression fixed and adjust rebound only.
I'll definitely give the KW's a hard look since they are a true 2 way.
Old Dec 26, 2007, 09:43 AM
  #37
GTWORX.com's Avatar
Yeah, rebound and compression with 1 knob. Not my thing really.
Ohlins single adjustment is rebound only, the way it should be.
We've been really happy with KW.
- Andrew
Old Dec 26, 2007, 09:46 AM
  #38
GTWORX.com's Avatar
7k front and 8k rear is a popular set-up of ours for that kind of usage. Great handling, and ride quality is still good too.
- Andrew
Old Dec 30, 2007, 11:16 PM
  #39
donour's Avatar
This is kind of off topic, but you have looked at these:
https://www.evolutionm.net/forums/sh...ighlight=zzyzx
They've generated a bit of buzz in the subaru community but evom hasn't really been talking about them. They are priced similarly to the KWs (once you add camber plates and rear topmounts).
d
Old Dec 31, 2007, 12:03 AM
  #40
sleeper3's Avatar
d
That's funny, I just started reading up on the zzyzx earlier tonight to learn more about them. Thanks for the link, I'll definitely consider them when the time comes.
Old Dec 31, 2007, 12:27 AM
  #41
R.over's Avatar
What spings will give the lowest ride hight and still have desent handling? Swift? GTWORKS? Some others?
Edit: With MR Bilsteins shocks
Old Dec 31, 2007, 07:41 AM
  #42
chrismnj's Avatar
swift will drop your car more
Old Dec 31, 2007, 08:19 AM
  #43
GTWORX.com's Avatar
Chris is right, Swift if you want the drop.
- Andrew
Old Dec 31, 2007, 08:34 AM
  #44
GTWORX.com's Avatar
d
They look pretty good. Koni is good stuff and zzyzx knows what he's doing. Their 2 ways are a bit more then KW's, but I'm sure they're great.
- Andrew
Old Dec 31, 2007, 09:50 AM
  #45
donour's Avatar
To be fair, it is not really and apples to apples comparison. The zzyzx price includes custom springrates and has a trick bolt on the lower bracket that allows enough camber to forgo plates for a lot of applications.
I don't really know much about the KWs, but I read somewhere that they also use koni inserts. Is this true?
d
Quick Reply: struts vs. coilovers
