Alignment help
Old Jan 10, 2008 | 03:56 PM
Jordanz3's Avatar
Alignment help
Recently I hit a huge pot hole where my front left rim got bent. The front left wheel also seems to be tilted inward. I guess it was the camber that got screw up for the impact. So today I went to firestone to get it aligned, they said the camber and caster is not ajustable on the evo. Is it true? However I do have coilovers with adjustment for camber. I guess they don't know about that. So my camber for the FL is -2.8, FR is -0.7. To me the FL wheel still looks titled inwards. So is this problem easy fix for a performance shop that knows how to deal w/ coilovers or did I bent something??? Thanks.
Old Jan 10, 2008 | 04:14 PM
donour's Avatar
Nevermind. I misread.
Old Jan 10, 2008 | 04:15 PM
CRX2EVO's Avatar
never ever take your Evo to Firestone
Old Jan 10, 2008 | 04:23 PM
Psquared's Avatar
True: There is no stock adjustment for Caster on the evo. I just typed this long reply...then realized you are running coilovers...I would just check for bent stuff..maybe some loose bolts or something that may have shifted...
Old Jan 10, 2008 | 04:36 PM
Jordanz3's Avatar
can they have just be able to adjust the camber from the top on the coilover?
Old Jan 10, 2008 | 05:59 PM
donour's Avatar
Firestone Complete Auto Care stores are locally owned so your mileage will vary. The one I use does awesome work.
d
Old Jan 10, 2008 | 06:02 PM
donour's Avatar
It depends. If you have camber plates, then it can be adjusted there. The OEM fronts adjust camber through an eccentric bolt on the lower strut bracket. See the shop manual for directions on how to adjust it. This bolt is _NOT_ in the firestone alignment settings computer (the old one or the new laser ones), but it's easy enough just to point it out to the tech.
d
Old Jan 10, 2008 | 06:17 PM
BlueDemon's Avatar
d
Mine too. They adjusted my camber setting to be -1.5 front and -1.0 rear with 0 toe and it feels great on the stock setup .
Old Jan 11, 2008 | 12:04 AM
lv05evo's Avatar
My old alignment guy told me I couldn't adjust it to -1.5. He told me it's only -1 or -2 camber. I'm going to try some toe in(or out I forgot now) to see if it make the car a little more stable in the turns.
To answer Jordanz3 original question, looking at -1 camber(Your FR tire) then looking at almost -3 camber(Your FL tire), there will be a very big noticeable difference. Even -1 camber difference is very noticeable. When I had my 05 Evo, I hit a big pot hole, and it threw off my camber. My car handled "loose" and the left tire had a very noticeable difference in camber wear. I got new tires and a good alignment, and never had a problem again with uneven wear. So if you want your tires to last, get an alignment right away so that all your tires can wear evenly.
Old Jan 11, 2008 | 08:32 AM
donour's Avatar
The two settings are marked -1 and -2, but the -2 setting usually comes out to about -1.5 degrees of actual camber.
d
Old Jan 11, 2008 | 09:40 AM
cfdfireman1's Avatar
They are dead wrong. And the caster can be changed a bit also, I've done it.
Blacksheepdj
Lancer Troubleshooting
114
Dec 7, 2008 09:14 PM
evokel
11
Mar 5, 2008 03:37 PM
falcontx
Jan 31, 2008 10:29 AM
Blue_by_u
11
Sep 24, 2004 09:56 PM
iodine23
Apr 12, 2004 08:55 PM
