Need help choosing coilovers for the track
Ok, was going to or der JIC race coilovers from kingkyle but they were out of stock or something like that..
So.. now i need to quickly order some "race" coilovers for track use from someone else, i want some good coilovers also in the 1500-2000$ price range, spring rate about 10-12k.
Will also buy some wheels like NT03 17x9,5 or similiar (5zigen, etc)
So the dealer must sell both wheels and coilovers
Please give me some pointers.
thanks.
thanks.
living in sweden, the only coilover you want is going to be ohlins, 1 because they are just about one of the best coilovers you can get for the evo, 2 to get them rebuilt, you can send them down the street.
i have ohlins single adjustables and havent put them on yet but craftsmanship is top notch, this year the majority of evos that won trophy positions at autox nationals were on ohlins so they are proven to work also. i will be running somewhere between 14 and 16k springs with a higher rate in the back
thanks.
thanks.
Hi and thanks for your reply
The car will be used mostly for track but not only..
I don't want 18 inch wheels because I don't want to use spacers or do fender rolling.
Öhlins coilovers are too expensive for my budget..
You should visit the motorsports forum instead of this one. You should list how much you have to spend on hardware and how much you are willing to spend on dialing them in.
Being in Sweden it may be hard to get anything we recommend.
Hi Andrew/GTWORX
I would like harder spring rates on the KW:s than 8/7.. more like 10/12 or 12/14.. is that possible?
Do you have the 5zigens or enkei nt03 in 17x9 or 17x9,5?
If you can get me these parts i will most prob be a customer soon..
These coilovers are meant for cars with high grip/race compount tires.
Is there really no one that can point me to a company that sells both a nice 17x9,5 inch wheel like ENKEI NT03 or RPF1 and also sells some tough suspension at about 2000$ with spring rates like 10k/12k??
Help!
Help!
you can go to tougefactory.com they have wheels you are looking for [i see it in the showroom] and they have stance coilovers that are below your $2000 price point. I dont know about the spring rates. im pretty sure that they have the ones that are specific for the evo [i am getting a set of stance COs on my evo8 ^_^ ] use the search and you can see ppl talking about the stances in the forums ^_^
Ohlins Sportline DFVs, KW V3, ZZYZX EM series when including camber plates and rear pillow ball mounts will probably easily run over the $2k mark. The Bilstein PSS-9 will be cheaper but will also be softer and are built with regular steel (rust). Unfortunately in this game the rule of thumb applies, you pay for what you get.
If you can work out a deal on KW V3 coilovers with GTWorx. Check out this US based website for some nice deals on rims.
http://www.discounttire.com
Good luck.
SousaPalooza
May 13, 2016 05:57 AM
EZ MONEY
15
Nov 29, 2012 02:23 PM
holycrap300
10
Dec 12, 2011 09:43 PM
aboogabooga
36
Feb 13, 2011 06:11 PM
3VOIXMR
21
Feb 2, 2009 09:36 AM
