Installed pads and rotors...need HELP!!
Old Feb 7, 2008 | 03:56 PM
Evo-IX-MOMO248's Avatar
i put dba 4000 series slotted rotors and hawk hps pads...we only did the front and i went to go drive it and it now seems like the brakes are "ON" when i start to move...almost like when you drive with your ebrake or something. We also noticed little shavings on the inside wheel...do they need to break in that much that they actually feel like its stopping when you start moving...or is something wrong?
Old Feb 7, 2008 | 04:01 PM
HaVoC RR's Avatar
i would go over everything again
Old Feb 7, 2008 | 04:08 PM
bump...i didnt want to move it if this isn't normal when you replace pads and rotors...are they supposed to feel that tight before you break them in??
Old Feb 7, 2008 | 04:11 PM
TSiAWD666's Avatar
You could try adjusting the master cylinder rod behind the brake pedal back a bit... err assuming this exists on the evos. It's there on my Eclipse and I've had to play with it before.
Old Feb 7, 2008 | 04:15 PM
Smike's Avatar
bump?
You got sound advice there - recheck everything.
Sounds like you did it wrong. Check the 2 caliper bolts for correct torque (80 ft/lbs) and make sure the pads are in correctly.
And...no there should be no friction (well noticable) from the pads unless your foot is on the brakes.
Old Feb 7, 2008 | 04:29 PM
sharkm87's Avatar
did you push the pistons back? prior to installation
Old Feb 7, 2008 | 04:33 PM
blazex50's Avatar
if your confident u did everything right just greese the brakes in those niples off to the side and see wat u get from there workd for me ppl always ignore the obvious
Old Feb 7, 2008 | 04:50 PM
there is friction...like the ebrake is on...the car wants to stop.
there is a slight scrapeing sound comeing from the front left mostly.
i dont even want to take it out of the driveway the way it feels or sounds.
Old Feb 7, 2008 | 05:15 PM
alright so i left the car at the house we were doing the installation on...he's gonna take it apart again tomorrow and look at everything...but has this happened to anyone after changing rotors and pads?
is it supposed to feel tight and after you drive they break in and feel normal...the scraping i know isn't normal but hopefully tomorrow we can figure it out.
Old Feb 7, 2008 | 05:40 PM
cfdfireman1's Avatar
ahhhhhhhhh what?
ignore this advice I have no idea what he's talking about and neither does he.
if you have little shavings that's a bad sign, sounds like you may have installed 1 of the pads backwards,metal side toward the rotor.
Old Feb 7, 2008 | 05:46 PM
EvoKnievo's Avatar
or you could have:
put the calipers on the wrong side of the hub. (this would be really really bad)
to much fluid in the resevior causing the pistons to not retract properly
pads on backwards (also really bad)
just go over and check everything twice! some pictures could help us narrow this down a bit more.
good luck!
Old Feb 10, 2008 | 09:13 AM
updates?
Old Feb 10, 2008 | 12:11 PM
djh's Avatar
djh
Check that you didn't forget the washer on one of the caliper bolts. It's just long enough to contact the rotor.
Dave
Old Feb 10, 2008 | 02:30 PM
afmafia's Avatar
I Would Take Everythingn Apart And Redo
Old Feb 10, 2008 | 07:53 PM
Dave
Forgot to update but the next day my friend took it back apart when i was at work...and dave (2 posts up) you got it right...he forgot to put the washer back in. Which then made the bolt just slightly rub on the inner circle of the rotor which is where i was getting the shavings from. But when my friend was taking it back apart he also noticed that the bolt in the caliper got cross threaded so the cars been at his house for the passed couple days. Hopefully tomorrow i can borrow my friends tap and die set to re-thread everything and get this thing back.
