Best spacers?
Best spacers?
I am looking for a good set of spacers that are known to not give vibration issues. I just got P45Rs and have a 8mm non hubcentric spacer.
At highway speeds the steering wheel has noticeable vibration. I believe it is the spacers.
I am looking for a good set of spacer that would clear this issue.
Anyone know of any good sets that are known to have no vibration issues?
Thanks guys!
Thanks guys!
Any hubcentric ones are going to be better for getting the wheel centered, and getting rid of the vibration. I have kics and can't complain. h&r are also a reputiable company... not sure if they have 8mm though
Actually going to get a custom set made from www.wheeladapter.com.
^^^ +1. What he said above.
Wheeladaptor seems to make good hub adapters which are hub-centric as well as wheel centric. Foe example - You need to tell him the bore on your wheel as well, so he can put a lip on the spacer to keep things kosher.
I just got off the phone with the guy a sec ago.
Also, depending on spacer size, you will need extended lug studs. I suggest ARP (part # ARP 100-7717) from summit racing.
Good luck!
Good luck!
Looks he cant make the spacers wheel centric for P45Rs because the bore is the same as the hub bore and im going to need +5mm. He did however say he would make them hub-centric. I will be getting them on Tuesday... We'll see how it goes.
lznk41
17
May 2, 2020 07:18 AM
Freebs
13
Feb 18, 2010 04:23 PM
vortico
Mar 9, 2009 12:09 PM
bluemm
22
Jan 28, 2008 09:20 PM
