Camber Plate squeak
Old Apr 23, 2008 | 02:16 AM
fvaldes's Avatar
Camber Plate squeak
I just installed a set of KWclub sport coilovers from Robispec and I can't be any happier. The thing is that there is an upleaseant squeak from the front units and Robert told me that for sure it is the camber plates because they are metal to metal with the car. What do you guys think about this? How could I solve this problem?
Old Apr 23, 2008 | 08:32 AM
GroundHog's Avatar
with the car on the ground, unbolt the strut tower bolts and then retorque them. maybe that will let them settle to the right spot.........iono, just an idea.
Old Apr 23, 2008 | 10:33 AM
fvaldes's Avatar
Thanks for the advice. I will do that and see what happens. It won´t hurt to try. Thanks again.
Old Apr 23, 2008 | 03:20 PM
DaWorstPlaya's Avatar
Which camber plates are you using?
If you are using the Ground Control camber plates, those suckers are known to be LOUD! ... and its due to their inherent design, so there is little to nothing you can do about those, unless you are willing to change camber plates..
Old Apr 24, 2008 | 10:11 AM
GroundHog's Avatar
i've got cusco's, not a peep.
Old Apr 24, 2008 | 02:25 PM
kduncan01's Avatar
If you have GC camber plate DO NOT UNBOLT WHILE THE CAR IS ON THE GROUND!!!
Because this design camber plate is on top of the strut tower (not under the strut tower like other designs) the car HAS to be supported on a jack or jack stand.
The GC plates are very good, they do need some high pressure grease to prevent from making noise. Remember the GC plates have camber and caster adjustment so there is alot more involoved than the regular camber plates.
Old Apr 24, 2008 | 02:27 PM
GroundHog's Avatar
wow, didn't know that. thanks for the save!
Old Apr 24, 2008 | 03:34 PM
Eratek's Avatar
go to a craft store and find some thin sheets of rubber. jack your car, pull the suspention, use the camber plates as a template on the rubber. make your cuts and place those peices on top of the camber plates before reinstalling them. leave extra material around the edges about 1/2 inch. that should make for some quite riding.
let us know how it goes.
VMC216007
Apr 6, 2015 09:53 AM
hamagc
Lancer Troubleshooting
23
Jan 6, 2011 09:16 AM
LooneyToon
May 11, 2009 05:25 AM
PaRanHaNeul
Sep 12, 2008 07:46 AM
kingkyle
Apr 28, 2005 06:36 AM
