Axxis brake pads
Axxis brake pads
does anyone use these?
do you like them? worth the money?
i only drive the car on the street so no need for any special brake pad, just looking for something that will give me the closest to stock feel
im planning on getting them for my front brakes. do i need new rotors when i do this or do i need to machine them? someone told me you can just change the pads and it will be fine, no need to mess with the rotors. is this true?
the car only has 18k on it, but my front brakes make like a grinding sound when applied, and a squeaking sound when im just driving. so im figuring its time for new pads
JohnL
but yes, no lubrication needed - and they are completely silent.
where do you get them and how much are they?^^
anyone else you axxis pads?
i just went out and took my wheel off...
the outside pad on the drivers side(the one you can see through the wheel) is in good shape, still a lot of meat on it. but the inside pad is gone....
is this normal? i havent looked at the otherside but they are probably okay since the noise is only from the drivers side
i wore my insides pads to metal. before the feeler on the outside pads even started squeeling. you will need to resurface the rotors - if you grooved them.
i got 50K out of my rotors - so i just replaced them.
girodisc has the magic pads.
drewblueeye
223
May 14, 2008 06:24 PM
volkskid
Apr 5, 2008 11:50 AM
Thwack
Jul 20, 2004 06:30 PM
