offset
Old Aug 27, 2003 | 08:29 AM
EVOMIZ's Avatar
offset
anyone know the offset for 18" wheels on a evo 8 and whats the best tire size ? i was looking to do 235 45 18 or 245 40 18.
anyone with pic's of hyper black rims on a blue by you evo ?
Old Aug 27, 2003 | 02:13 PM
mprtklr's Avatar
i am doing Volk LE-37T Gunmetal/polished lip 18x8.5 +30 offset 5x114.3 BP. and i am getting 265-35-18 tires.
Old Aug 28, 2003 | 05:35 PM
EVO_RPM's Avatar
damn 265 will that fit good? Haven't seen that setup yet. I wonder if that will run if you lower it
Old Aug 28, 2003 | 05:53 PM
mrdecibel's Avatar
Thats too much tire for the EVO and an 8.5 in wheel. Scratch ever lowering that more than a 1/4 inch.
Old Aug 28, 2003 | 07:39 PM
SRD's Avatar
SRD
I beleive Works runs 265s on 18 X 8.5"
Old Aug 29, 2003 | 05:10 AM
Neal@tirerack's Avatar
I have 235/40-18 and 255/35-18 being the best fitments for the car. 235's will work on 8.00 to 9.50" wheels, 255's will fit 8.50 to 10.00". The car MIGHT handle a 265 but I can't guarntee it.
265's are a bit too wide for an 8.5" wheel. 9.00-10.00" is the best fit for a tire that wide.
Old Aug 29, 2003 | 09:28 AM
mprtklr's Avatar
265 sits fine, and it is identical to the height of the 245 with 40 series tires. its not too wide, it will give more meat to the edge. to protect 3000 rims...
and my car IS lowered. the wheel gap is perfect.
Old Sep 2, 2003 | 04:47 AM
aig's Avatar
aig
What about 18x9.5 Volk te37 30 offset. Does it fit ?IF yes, What size tires? Also , 18x8 35 offfset. Will it work?Thanks
Old Oct 20, 2003 | 11:43 PM
gb-motorsports's Avatar
bump ! anymore fitting issues that need answers?
Old Oct 20, 2003 | 11:56 PM
value's Avatar
EVOMIZ offsets really depends on which wheels you intend on running. With the EVOs brakes you have to be careful. AIG your TE37 in 18x8.5 will need a +30MM
Old Oct 21, 2003 | 09:44 PM
true on+30.. 265 is cool on 35 series and hieght is same as 245 40 or 255 40's... Iwill run a 18x8.5 +30. TC2's and get a 245 40 tire..
Now not all tires sport the same sidewall/edge that clears. Continental Extreme contact for example are so squared (wide stance on all tire sizing/looks bad ***) but that it will not clear some applications, so choose your tires wisely.
cheers
gino
08ev
Oct 24, 2016 04:51 PM
eldooo
Feb 26, 2015 08:25 PM
jay_jay_n
Feb 28, 2006 07:26 PM
d1_evo
May 1, 2004 04:50 PM
Mister2zx3
Aug 14, 2003 05:27 AM
