is the fender liner needed?
Old Nov 16, 2008 | 07:29 PM
def1's Avatar
Just wondering before i buy a new one. My tires rub the hell out of my fender liners and one completely fell off. Does this affect downforce or drag or lift at all?
Old Nov 16, 2008 | 07:35 PM
itzcharlez's Avatar
um.... i would say yes their needed..
i dont think you want all that water and dirt getting in there..
Old Nov 16, 2008 | 07:44 PM
def1's Avatar
i dont care about that. thats what my undertray is for. I just wanna know how it will affect me on the track.
Old Nov 16, 2008 | 07:47 PM
sharkm87's Avatar
well without it, you will be kickin up snow and dirt or whatever into your engine bay and into your door jams...obviously you should replace it.
Old Nov 16, 2008 | 08:29 PM
EvoIXMRSEPilot's Avatar
also in more of an extreme sens it adds aerodynamic stability at triple digit speeds. Don't compromise OEM design just so your car can "Sit Hella Flush"
Old Nov 16, 2008 | 08:36 PM
Smike's Avatar
Its needed and they are cheap - fix it. There are wires that run under then also. A rock into those wires could cut them, introducing a whole new problem.
Old Nov 16, 2008 | 08:37 PM
Bggstin's Avatar
I have the same problem. I checked it out and OEM's are ~$100 a piece. I think it's worth it. I hate the thought of dirt getting everywhere it shouldn't be. Even more annoying than that is my ever so slight vibration in the steering wheel at random times. I cant really do a temporary fix because it wore through all the mount holes already and theres not much left to the fronts.
Old Nov 16, 2008 | 09:18 PM
sharkm87's Avatar
which side did u need? i recently bought a set of both but only needed the driver....i still have passenger side
Old Nov 17, 2008 | 12:03 PM
binarysleep's Avatar
AMEN! The ABS crash sensor routes right through there; The inner fender is all it has for protection from the elements.
Also, imagine what your fender would end up looking like with a million little dimples from rocks flying up dinging the inside of the fender.
Old Nov 17, 2008 | 06:55 PM
slvrr's Avatar
How much do you want for it?
Old Nov 18, 2008 | 07:57 AM
def1's Avatar
what should i do to prevent it from happening again.
my car is not even lowered. Its just the running 265-35-18 that is killing me.
Old Nov 18, 2008 | 10:18 AM
chaotichoax's Avatar
raise your car or get wheels with a different more friendly offset
Old Nov 18, 2008 | 08:19 PM
MitsuJDM's Avatar
araz5260
Nov 17, 2014 08:50 AM
TwStDeVo
Jul 19, 2013 06:24 PM
nollij
Jun 23, 2013 11:37 PM
RAY101381
11
May 4, 2012 08:10 AM
diablo2184
Oct 10, 2009 07:53 AM
