Spacer Needed?
Old Feb 28, 2009 | 01:33 PM
SoflaEvo9's Avatar
Spacer Needed?
I picked up my Evo 9 from a local dealer with a bent stock wheel for 18,000 with 20,000 miles on it. Ordered a set of Advan TCII 18x9.5+35 and I have looked everywhere to check if a spacer is needed or not. The car is on megan coils right now. Im thinking the front might need a spacer, but I dont know about size. Anyone think they can help me out? I have abused the search key endlessly. Thanks.
Old Feb 28, 2009 | 08:10 PM
kekek's Avatar
Most likely you will need a front spacer. How thick will depend upon the coilovers and tire size. Some of the factors are how much neg camber you run, what the OD and position of your springs are, the design of the coilover lower mount, etc. My guess is probably around 5-15mm will be necessary.
Best thing to do is have a tire mounted on the rim and put it on the car. Buy some washers and load them onto the lugs until you have enough clearance between the coilover body, spring or spring perch (these are the tight points). Then measure the washer stackup thickness and order the appropriate spacer. Make sure the measurement is done when the camber has already been set as this can have an effect on the necessary spacer (the lower bolt changes the position of the strut relative to the wheel).
Edit: Don't even think about driving the car with washers as your spacers, this is a fitment tool only!
Also take note of how much thread engagement you have. Chances are you'll need longer studs or spacer with a built in stud.
HTH
John
Old Mar 9, 2009 | 02:32 PM
SoflaEvo9's Avatar
Thanks for some info. Is there anyone that has first hand experience with the Advan TC-II? Someone else suggested a spacer may not be needed at all?
Old Mar 9, 2009 | 05:09 PM
prj.evo's Avatar
You might just need spacers in front to clear the calipers. Id probably just wait till you get them, then mount them up and see if they clear.
Nelson999
Sep 11, 2014 12:06 PM
eder-loco
Feb 14, 2012 07:34 PM
evobros
30
Aug 30, 2010 10:02 PM
scothu
Jul 25, 2010 01:29 PM
Dosagex
Jan 27, 2010 07:08 AM
