wheel bearing??
wheel bearing??
how do you know if you have a bad wheel bearing, if i take it off how do i tell? My car makes weird loping noise at all speedsand is worse while braking, rotated the tires and the noise stayed in the front left
One easy way to tell if you have a bad wheel bearing is to jack the car up so the wheel is off the ground, then grab the tire at 12 o'clock and at 6 o'clock, and try to shake the wheel (i.e. = push at 12, pull at 6, and vice versa). If you get any excessive movement, I would replace the bearings. Check all the wheels.
A bad wheel bearing starts to make a whirring, groaning kind of noise. At first, it will only be when that bearing is under increased load, i.e., the on outside wheel of a turn. If it does this when turning, but not when straight, thats a pretty clear sign. If it does it all the time, its either a totally shot bearing or something else, like a bad differential, gearbox , etc.
The wheel bearings on the Evo are apart of the hub assembly. You have to buy a whole assembly, you cannot just get a bearing. Around $180-200 for the assembly.
NixLancer
29
Feb 14, 2018 05:19 AM
a4rontran
14
Jun 18, 2013 06:29 PM
