CBRDs Best street coilover...
Old Aug 9, 2010 | 10:43 AM
  #46
IMPORTIMAGE's Avatar
Originally Posted by RCEsterly
Does anybody have any information on BC Racing coilovers?
BC is a very good coilover, custom spring rates free of charge as well as valving. 1 year warranty too! Let me know if you want further info
Old Aug 9, 2010 | 11:00 AM
  #47
CBRE's Avatar
Id say his Ohlins DFV's, everyone who's rode in my car said they ride better than stock.
Old Aug 23, 2010 | 06:02 AM
  #48
STi*guy.kiev's Avatar
Guys anyone with the sachs?
Works has the
Old Aug 23, 2010 | 06:08 AM
  #49
TURBevO8's Avatar
Next time I am out at PRP if you are there we can exchange rides and see the difference. I would like to know personally.
Old Aug 24, 2010 | 02:49 PM
  #50
CBRD's Avatar
Works has the
Sachs makes very nice dampers.
cb
Old Aug 24, 2010 | 08:09 PM
  #51
lttletimmy's Avatar
I'd love to hear more about how the Ohlins ride on the street, seriously considering these.
Old Aug 24, 2010 | 09:12 PM
  #52
R/TErnie's Avatar
cb
Chad,
I'd like to hear what your experience is with running high rates on non-revalved Ohlin's DFV's. I current run 12k Front and 16k Rear springs and I'd like to switch to the DFV's and run the same rates.
In your experience can the dampers damp that high of a spring rate effectively?
Also in your experience (using linear pots or seat of the pants) What is the HIGHEST spring rate you've ever run successfully in a revalved DFV?
Also what size tire/slick do you run your 1000# rates on? weight of vehicle?
Old Aug 25, 2010 | 04:31 AM
  #53
metalsaber's Avatar
My Ohlins R&T coilovers are just as good if not better ride than the stock MR suspension. I'm running a 10k/10k setup.
Old Aug 25, 2010 | 11:11 AM
  #54
lttletimmy's Avatar
Have you ever tracked this setup? I'm looking at the 8k/10k setup with a TRE rear diff.
Old Aug 25, 2010 | 11:22 AM
  #55
metalsaber's Avatar
I've only had it out for AutoX a couple times so far. Seems to do well. I'm going to get my Rear Diff done as well. On street tires the car still understeers and the rear diff seems like the best option to solve that. I also have a set of wider wheels/tires coming as well.
Old Aug 25, 2010 | 11:44 AM
  #56
CBRD's Avatar
Originally Posted by R/TErnie
Chad,
I dont like going up more than say 250 lbs on a rate on these dampers... on the standard valving...
I typically feel if you think you need more than a certain spring rate (depending on the package the car has) you should go to a JRZ or similar double adjustable with remote res. where you can also change the canister pressures and have a wider range of adjustment..
there aren't alot of clients that I would say need that.
Our car that runs over 1000lbs springs weighs in the low 2700 lbs range with around 695hp crank hp on 93 octane...
cb
Old Aug 25, 2010 | 12:33 PM
  #57
DaveGSR's Avatar
Thanks to this thread, I have a box from H&R waiting outside my door for my Evo X. Hopefully I'll be as impressed as you are by these on the 8/9 platform, Chad.
Old Aug 30, 2010 | 06:27 PM
  #58
R/TErnie's Avatar
cb
I assume you're running 285's on a 10.5" wheel? Slicks or R comps?
I looked into the JRZ double adjustables and the Moton's, but honestly it was about twice as much as I could spend. ~ 6k I opted to take a small step in the right direction and got the DFV's. I suppose when I feel i've outgrown these I can always graduate. Thanks for the information. Greatly appreciated.
Now get me a BB turbocharger.
Old Aug 31, 2010 | 10:55 AM
  #59
CBRD's Avatar
ahahahah lol nice BB comment!
yeah the JRZ and Moton stuff is big bucks.... i love the ohlins too and the HR.. all good stuff,
our TA is 285 on a 10.5 on A048s
cb
Old Aug 31, 2010 | 11:59 AM
  #60
dbsears's Avatar
Finally pulled the trigger on some DFV's huh It's about time Lemme know what rates you end up running.
