can the camber be changed during alignment?
Old Oct 27, 2003 | 05:43 PM
Gumpy's Avatar
I am wearing the insides of my tires (all 4) only. The other parts of the tire are in great shape. Took my car to the dealer (who was overbooked that day) for an alignment and they said the the camber on the EVO 8 is not adjustable. They said that if they did the alignment, that would not change the camber. Is this true? I have seen camber kits out there, but most of these are doing what I am trying to avoid by adding more negative camber. This car is my daily driver and I need to get snow tires soon, but don't want to wear brand new tires unevenly. Can anybody help me out here?
Thanks,
Chad.
Old Oct 27, 2003 | 06:13 PM
Evilution VIII's Avatar
Im curious about the front camber adjustments also,
i was told it was non adjustable but on an alignment machine for instructions for front camber adjustment on the evo it showed an eccentric with two settings -1 and -2. is this -1 degrees and - 2 degrees?
Old Oct 27, 2003 | 07:57 PM
DGS's Avatar
DGS
According to the online service manual (before it became a pay-subscription service), there are two selections for front camber: -1.00 deg and -2.00 deg (plus or minus 0.5 deg).
FRONT
ITEM SPECIFICATION
Toe-in mm (in.) 0 ± 2 (0 ± 0.08)
Steering angle Inner wheel 31°45’ ± 1°30’
Outer wheel (reference) 27°15’
Camber (selectable from 2 options) -1°00’ ± 30’ or -2°00’ ± 30’ (Left/right deviation within 30’)
Caster 3°55’ ± 30’ (Left/right deviation within 30’)
Kingpin inclination 13°45’ ± 1°30’
Lower arm ball joint breakaway torque N·m (in-lb) 0.5 - 3.4 (4.4 - 30.1)
Lower arm pillow ball bushing rotation starting torque N·m (in-lb) 0.5-3.0 (4.4-26.6)
Stabilizer link ball joint turning torque N·m (in-lb) 1.7 - 3.2 (15 - 28)
REAR
ITEM STANDARD VALUE
Toe-in mm (in) 3 ± 2 (0.12 ± 0.07)
Camber -1°00’ ± 30’ (Difference between right and left within 30’)
Thrust angle 0°00’ ± 0°09’
Upper arm ball joint turning torque N·m (in-lb) 0.5 - 2.5 (4.4 - 22)
Trailing arm ball joint turning torque N·m (in-lb) 0.5 - 2.5 (4.4 - 22)
Assist link ball joint turning torque N·m (in-lb) 0.5 - 2.5 (4.4 - 22)
Assist link slide bushing turning torque N·m (in-lb) 0.5 - 2.0 (4.4 - 17)
Lower arm pillow ball bushing turning N·m (in-lb) 0.5 - 3.0 (4.4 - 26)
Stabilizer bar link ball joint turning torque N·m (in-lb) 1.7 - 3.1 (15 - 27)
Sorry about the formatting, but I can't seem to do tables in vBcode.
Old Oct 28, 2003 | 04:49 PM
Gumpy's Avatar
DGS,
Thanks for the information. It looks like the minimal amount of camber I can have is -1degree. Mine has to be -2degrees now as the insides of the tires are wearing badly. I will take this info with me to the dealer and get it aligned and ask to set camber to -1 degree front and rear. Hopefully, this will prolong tire life somewhat. Thanks again.
Chad.
Old Oct 28, 2003 | 07:49 PM
erioshi's Avatar
Gumpy - have your toe checked also. Excessive toe-in can cause exessive wear on the inside edge of the tire.
Old Oct 29, 2003 | 06:33 AM
8th_Sin's Avatar
a good way to tell if the wear is from toe or camber is this...
Rub your fingers along it, if it is a bumpy feel it is usually casue by toe. If it is a smooth feel it is usually the camber.
Old Oct 29, 2003 | 04:28 PM
Gumpy's Avatar
looks like a toe problem
It is a bumpy feel. Probably a toe problem then. Thanks.
Gumpy.
Old Oct 30, 2003 | 08:14 AM
Ruff's Avatar
Hey Gumpy do you have any suspension mods on your car like springs or something?
Old Oct 30, 2003 | 05:00 PM
Gumpy's Avatar
Nope. Car's suspension setup is stock.
Gumpy.
Old Nov 11, 2003 | 04:43 PM
Gumpy's Avatar
was a toe problem
Got my car aligned and it was a toe problem. Thanks to 8th sin for the tip. Now off to get all-season's put on this weekend. I would have to say if you just bought an EVO, spend the money and get it aligned. Most are off from the factory. It is cheaper than new tires.
Gumpy
Old Nov 11, 2003 | 10:04 PM
boostedwrx's Avatar
11k miles on the advans.. no signs of obscure wear even with a driver that doesnt know part throttle!
Thanks for posting the fac specs though, I need an alignment with the jics..
Old Nov 26, 2003 | 09:18 AM
twdorris's Avatar
A bit of grave digging here, but not too bad. I finally checked by tires yesterday (21,000 miles). The inside of the front tires are worn to the chord! The car is crazy twitchy, especially at lower speed, which first made me think of a toe problem. Then to see that kind of wear on the tires (really bumpy, uneven tread too) pretty much confirms it. Geez. This thing has to be way out of spec.
Time for new tires anyway. So not that big a deal. Just annoying that it's so far out and was probably like this the day I picked it up. Both sides were worn almost identically.
Thomas Dorris
Old Nov 26, 2003 | 05:29 PM
8th_Sin's Avatar
after all this I notice my own tires after 2000 miles. I seen the typical uneven dirt as I walked up my driveway. I have seen this many times on my GSX. Well I ran my hand along the outside of my tires, sure enough some cupping in action.
BTW how ya doing Tom, I am a link owner and I believe we have a mutual friemd named Bob Friend.
Old Nov 28, 2003 | 09:37 PM
pace's Avatar
I don't think you should much attention to the -1 and -2 camber indicators. On the alignment rack today, my car was reading -0.6 and -0.7 degrees on the left and right front respectively, with both set to '-2'. We had to add eccentric ('camber') bolts to bring the camber up to -1 degrees.
-Pace
pd9000
Dec 15, 2016 09:53 AM
kyoo
Nov 21, 2016 08:43 AM
19psi
13
Oct 8, 2006 09:08 PM
slvrevo
Apr 21, 2006 10:11 PM
