Custom Master Cylinder
Old Jan 9, 2010 | 06:04 PM
Evokid03's Avatar
Smile Custom Master Cylinder
Hey guys, as many know i have been workin on my car alot lately.. Im doing a fully rebuilt motor and eliminating as much weight off my SSL as possible.
Recently I got together with a Company (Name Undisclosed currently) to create a new Master cylinder kit for Evo's using. Not only does the kit look great but it saves tons of weight.
My main purpose for this is to give people another option when wanting to eliminate the abs system like me. Also give a new look and to lose a good amount of weight.
There are two different fluid canisters that can be used but i believe i will use the big one.
We are still in process of getting everything situated but this is what i have so far.
Pic of Product
Mock up
What is Eliminated
I will get full Weight of either item ASAP.
I really would like opinions and what you guys think.
Old Jan 9, 2010 | 06:32 PM
ch53avitech's Avatar
That looks really nice. How much was the new one and is it a straight bolt in? I'd like to see it when it's all done and with the motor in.
Old Jan 9, 2010 | 06:33 PM
chu's Avatar
chu
That's nice and all, but what are the performance gains?
Old Jan 9, 2010 | 06:36 PM
Evokid03's Avatar
A new Rs kit is about 450 w/ hardlines and Rs master cylinder.
SInce im in mid process of building my motor and car.. I will get pics of this on the car with a motor eventually
This kit is not for performance, it is made so people have another option instead of buying a RS NON Abs kit from mitsu when they want to delete the ABS.
Also this kit is for those weight freaks that like to get every bit of possible weight off the car and for the people like me that must have a Extremely Clean Engine Bay.
Old Jan 9, 2010 | 06:54 PM
0xDEAD's Avatar
That is actually really f1cking sweet.
Old Jan 9, 2010 | 06:56 PM
Evokid03's Avatar
^ Thanks
Old Jan 9, 2010 | 07:04 PM
EvoDan2004's Avatar
what was the weight savings and is it ok to delete the break booster????
Old Jan 9, 2010 | 07:07 PM
Evokid03's Avatar
Im still in search of a scale, i am giong to weight both the oem and custom kit completely.
Also , yes it is ok to delete the break booster.
Old Jan 9, 2010 | 07:12 PM
EvoDan2004's Avatar
how much harder will it be to use the brakes without a brake booster??
Old Jan 9, 2010 | 07:16 PM
Evokid03's Avatar
This shouldnt really change to much, but possibly be a bit harder in pressure.
TTP Engineering used a similar setup on there evo, may want to ask them for more info on it.
https://www.evolutionm.net/forums/ev...-drag-car.html
Its not as pretty though
Old Jan 9, 2010 | 07:17 PM
travman's Avatar
Man that is a sweet part......great job.
Old Jan 9, 2010 | 07:21 PM
Evokid03's Avatar
Thank you, if everything goes good. This kit will be released to Evom Members for Purchase..
Old Jan 10, 2010 | 02:24 PM
Evokid03's Avatar
comeon guys tell me what you think
Old Jan 10, 2010 | 02:32 PM
KX250Fmotoracer's Avatar
Are you putting in another booster?
If not the peal is going to be extremely hard with no booster and you're going to loose mechanical advantage.
Old Jan 10, 2010 | 03:13 PM
Evokid03's Avatar
^ Not all true, without running a brake booster yes it will indead increase the hardness of the pedal. But by using the proper side Mc, it will help with that issue..
Overall the pedal will be a bit harder but performance will not be decreased. The car will still have brake within the same distance.
I actualy have driven a car without a MC, the pedal was a bit stiffer but wasn't anything that i couldnt get used to.. I kinda of reminded me of a car with a aftermarket clutch.
In all we are working together to develop the best kit we can, while retaining the same specifications.
