grinding only while turning right.
Old Jan 28, 2010 | 08:17 PM
screwnutbolt's Avatar
i am experiencing grinding only when turning right. when im cruising at a good speed all it takes is a slight right input to influence the grinding. recently replaced the left cv axle due to popping bout 5000 mile back. i did visual inspections on the rt cv axle and wheel bearing. anybody have any input on this?
Old Feb 2, 2010 | 06:54 AM
EvoPooPoo's Avatar
jack up your car and perform the basic inspection.
check for wheel bearing (mostly likely not - you will hear humming)
ball joint
CV joint
check to see if anything is rubbing...
Old Feb 2, 2010 | 07:00 AM
TurboTim06's Avatar
u need brake pads
Old Feb 2, 2010 | 07:22 AM
Matt D.'s Avatar
I bet it's a left side wheel bearing. Turning right will load the left side of the car causing a bad bearing to howl. My right rear wheel bearing is going bad, the slightest left turn will cause it to make noise.
Old Feb 2, 2010 | 08:19 AM
SpoolinUp's Avatar
Silver Sponsor
Ditto here except right front, makes a weird grinding sound. I really need to get around to doing it.
I also have the telltale cupping on the tread.
http://www.procarcare.com/includes/c...dtirewear.html
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Feb 2, 2010 | 08:26 AM
Matt D.'s Avatar
What do you have for alignment? I'm running -1.0 or -1.5 in the back, unsure if this would apply to me.
gameapbt
Feb 24, 2016 07:06 PM
evo8mr04
Oct 7, 2015 06:50 PM
maxsideburn
Dec 7, 2010 09:10 AM
FoxFister
Jul 17, 2010 08:30 PM
scherejs
19
May 2, 2010 05:40 PM
