View Poll Results: Which would you chose...?
Cusco Zero2R
19
42.22%
Tein RA
13.33%
JIC - FLTA2
20
44.44%
Voters: 45. You may not vote on this poll
Looking for people with upper end coilover experience...
There is Moton USA for support here in the states - although i am floating the Idea of the Developing the Club Sport Model (steel outers - 2 -way adjustable, lower cost overall than the normal racing models) to them for the EVO. If they bite then there could be a lower cost Moton shock for the EVO, of course that is reletive since they will still cost 2.5K + for a full set + Springs.
Penske has it's hands full with other projects right now and typically you need to extremely specific with the entire spec for them. So unless your a racer and really understand suspension i would not go that route.
As i said before any of these options (Moton, Penske, JRZ) will require set up by a professional suspension person and expect to spend at least 2 full days at the track with them (at least 1500.00 for thier time) + track fees
This is not an endevour for the street driver nor do i see the value unless you are going to really race it.
[QUOTE]Originally posted by cupcar#12
[B]- DMS is another option (the 50mm setup).
If the JICs that we offer are not enough for you, consider that we are the southern California DMS dealer, we have used DMS products on our rally cars for many years, and we can tailor a DMS set-up to your particular needs. We have many years of set-up data to draw from, as we have specialized in turbo AWD Mitsubishi performance for the past decade.
Contact me off-list with any further questions.
john@roadraceengineering.com
Originally Posted by Changy
You considered the HKS Hipermax pro's? Iam using them and i think they work awesome on the race track. 36 stiffness levels to adjust. Abit too much for me though
I assume you 'test' the coilovers at Sepang? I experienced bad bouncing especially in the sweepers (Turn 5 and Turn 6). I'm on Ohlins PCV, 16/20 in front, 20/20 (full stiff) rear IIRC. I wonder maybe mine were set too stiff, or ride height too low (was set up LOWER than Ohlins factory spec), or combination of both
Wasn't impressed with the Ohlins on that outing. Although for STREET it is very good.
Originally Posted by Diesel
I'm going to be adding a set of coilovers over the winter, and am looking for opinions on what will suit my needs best...
I've narrowed my choices down to...
a. Cusco Zero2R
b. Tein RA
c. JIC FLTA2
I'm kinda leaning towards the Cusco at the moment, but am looking for anyones experiences with any of these... I really like the JIC as well...
How do they hold up over time...?
I'm not looking for any kinda "comfort" here... these are for ***** out driving... so you know what i am looking for...
Zeal was an option as well, but the pricing on those is way up there, and i think that these other 3 will exceed my needs as is...
a. Cusco Zero2R
b. Tein RA
c. JIC FLTA2
I would recommend either DMS 50's (street length) or Ohlins. In my WRX, I ran both the DMS 40's. IMHO, utter crap, but I also had a set of the earlier design before they found a fix for the stiction problems. To DMS's credit, they did eventually fix the problem. But their biggest problem is the bad reputation that this mistake caused. DMS 40's are great if you want the ride height adjustment without the super stiff ride. DMS does not recommend that anyone run more than a 225lb spring on the 40's. the inserts are not valved to handle anything higher.
I later ran DMS 50's on my WRX. These struts are built like a tank.... no crap. you can bomb down the roughest back road you can find and balence a tea cup on the dash and not spill a drop. The rougher the pavement, the better these work... They never totally failed on me, but the ride could become almost intolerable when they needed maintenance. When they were put back on after regular maintenance, the ride was better than a BMW (on all kinds of road conditions) the harder you through the car into the corner, the better these struts got (progressive spring)
The DMS 50's are alot like a super model girlfriend. you get the best performance for the money, but they are also high maintenance. On average, I had to regrease them every 3 months (the WRX was a daily driver). But again that was with DMS's old seal design.
The dude I sold them too has run them over 6 months now with no problems (updated seals) and absolutely loves them as he totally kicks **** on the autocross and track days...
I just picked up a set of Ohlins... These struts look excellent. Far better construction than DMS (sorry mark) for a similar price. I think at this point, the DMS 50 is more expensive than the Ohlins Road & track struts. But you do need to provide your own camber plates with both of these struts, so there is extra money involved if you consider these struts. I can't wait to put them on the car.
Vivid Racing
Evo 'For Sale' Suspension / Brakes / Handling
May 13, 2005 09:45 AM
BALtown
30
Dec 12, 2003 11:15 AM
