Need some brake part numbers...
I did a track day on Friday and had a blast, but when I changed out the rotors today, I found that the left rear caliper was missing one of the brake pad retainer pins and the spring/anti-rattle clip.
I have searched but I can't find any threads that list the part numbers.
The closest thing I found is a diagram showing a "clip set" that contains the springs and the pins, but no part number associated with it.
Can someone point me to the part numbers?
On a side note, I read some other threads where this has happened often on track days. Has anyone tried drilling the pins and using safety wire?
Thanks...
Thanks...
So it turns out the part numbers I want for an Evo 8/9 are:
MR475936 - - rear brake clip set
That includes 2 spring clips and 4 pins for the rear brakes
MR475935 - - front brake clip set
similar kit for the front brakes
I also found this information in the "part number" thread after a little more digging.
Look under:
clip set
brake retainer pin
anti-rattle clip
Hope this helps others out
Look under:
clip set
brake retainer pin
anti-rattle clip
Look under:
clip set
brake retainer pin
anti-rattle clip
Look under:
clip set
brake retainer pin
anti-rattle clip
bahnzii
MitsubishiParts.net - WA
Mar 16, 2010 11:49 AM
Knightr
44
Aug 14, 2009 06:44 AM
