Should this tire be replaced?
Fiancee sneezed taking a turn and clipped the curb. Is this bad enough to replace it or does it just not look as pretty? I figure if I go to a local tire shop, the answer is going to be "replace"...wanted to get some opinions from people without a dog in the fight:
actually tire sidewall structure doesn't look damaged, it's only special part of rubber to protect the rim that is clipped. My opinion is that the tire can easily be used for DD, but I'd not take it to any significant heating or load.
must say I'm not working with any tire company, hence my opinion should be taken FWIW
I've seen way worse and it doesn't appear to be any structural damage. I would run it on the front actually. If it were to blow you'll be able to control the vehicle. If it's on the rear and something happens you won't have as much control
I told my fiancee that and I was denied. (I'm from OT, couldn't let that pass)
It's the passenger rear tire...going to swap over to the spare just because she has a rather intense commute to work from St Helena, over the hills, into Santa Rosa. She's going to check with a tire shop there. It's a very tight, twisty two lane road so if she had a blowout, there is nowhere to pull over and change it and no cell coverage. Better safe than sorry.
leonevox
15
Jul 22, 2010 09:43 PM
urneighborhood
For Sale - Wheels / Tires
11
Sep 10, 2009 10:06 AM
