wow what a difference!
Old Apr 20, 2010 | 07:43 PM
n2oiroc's Avatar
bone stock 03 evo with swift spec r's. been driving around with 235/45R17 nankang ns2's and unaligned. got 255/40R17 star specs installed and realigned and the difference is absurd! i was expecting a dramatic change, but not like this! excellent tires!
it was aligned by the guy that does most of the alignments for the local guys running scca, he recommended a little toe for better tire wear and less understeer. the tires are still a little slick with mold release, but the specs seem great.
Old Apr 20, 2010 | 07:56 PM
BlitzkrgCT9A's Avatar
good job.. well done
Old Apr 20, 2010 | 08:01 PM
TurboTim06's Avatar
very nice! you will love the tires at the track
Old Apr 21, 2010 | 02:10 AM
robi's Avatar
Looks nice- a good alignment makes a world of difference. Ever consider offset LCA bushings?
-Peter@robispec
Old Apr 21, 2010 | 04:21 AM
Smike's Avatar
Good great. Once you get 300-500 miles on the Z1*s they will come alive for you.
Old Apr 21, 2010 | 04:52 AM
evremonde's Avatar
what would offset LCA bushing do? allow more -camber?
(answering for the op )
Old Apr 21, 2010 | 06:09 AM
Smike's Avatar
Corrects the geometry from lowering the car.
Old Apr 21, 2010 | 06:10 AM
n2oiroc's Avatar
The alignment guy said if i wanted more - camber in front he would just slot the struts. He could also get more out of the rear with some work but ill see how i like it as it sits.
Old Apr 21, 2010 | 06:50 PM
n2oiroc's Avatar
-Peter@robispec
i'll get to them. too many other things higher on the list right now.
Old Apr 21, 2010 | 06:59 PM
kyoo's Avatar
i thought the roll center adjuster did that ?
Old Apr 21, 2010 | 08:53 PM
BOOSTED_88's Avatar
Nice #'s I've heard nothing but good things about those tires.
Old Apr 21, 2010 | 10:58 PM
robi's Avatar
The offset bushings add caster by moving the rear of the control arm out and the balljoint forward .It's a stiffer bushing (hard bearing on the Perrin), so there's less deflection and dynamic alignment change. There's also a slight change to the anti-geometry.
n2oiroc
Aug 27, 2016 03:12 PM
n2oiroc
Jul 17, 2016 11:29 PM
n2oiroc
May 12, 2013 06:23 PM
n2oiroc
Apr 4, 2012 07:07 PM
n2oiroc
31
Nov 29, 2010 08:49 AM
