rear trailing arm ball joint question
I'm doing all the bushings in my evo and as i was using a stupid pickle fork i tore one of my dust boots on the ball joint. Can you replace the boot with maybe one of the front boots? Im replacing the front ones with whiteline kit.
Thanks
Thanks
this part popped both them off in 10 seconds. http://www.summitracing.com/parts/OTC-6297/
Also for future reference to help others on the forum the part number for a rear trailing arm ball joint dust boot is mb808555 and
can be found at mitsubishiparts.net
i just swapped my rear trailing arms. to get the ball joint out, i loosened the nut, then grabbed a big 1/2" extension, and gave it a few wacks with the mallet. came right out.
lucky you man. mine wouldnt budge with pb blaster or a 10# sledge hammer. When it seperated with that special tool above it sounded like the control arm snapped in half. Mine were STUCK.
j_barcarse
Jul 7, 2011 09:50 AM
xtnct
11
Jul 21, 2009 07:39 AM
Boost3dxEvO
Jul 9, 2009 07:02 PM
------ you can find it on ebay cheaper then hf i believe. $35 shipped.
