Lower Ball Joint
Old Feb 18, 2012 | 09:08 PM
bryonboals's Avatar
Lower Ball Joint
I am doing a rack & Pinion on my car and tried to remove the lower ball joint but could not remove so I just removed the A arm off the sub frame. When I used a Ball Joint fork grease came out of the boot. Can I have the shop repack it or do I need a New ball joint. I don't see a fitting to re- grease.
Old Feb 24, 2012 | 09:10 PM
PatricksEvilEvo's Avatar
You do realize this is an engine management/tuning forum right?
Old Feb 24, 2012 | 09:49 PM
bryonboals's Avatar
Could not find a suspension and steering forum...To answer my own question I got back from shop I have two options 1) replace the ball joint 2) use a needle nose tip on grease gun and pump grease back in where it leaked out. Just to let anyone know what to do if this happen to you
Old Feb 24, 2012 | 10:41 PM
vd's Avatar
vd
Let me help you a bit -> https://www.evolutionm.net/forums/ev...-tire-rack-23/
Old Feb 26, 2012 | 04:53 PM
bryonboals's Avatar
thanks
CaptainSquirts
Jun 27, 2017 03:36 PM
binky
34
Jun 25, 2017 06:53 PM
Jonno99
Sep 12, 2016 03:35 PM
R/TErnie
13
Mar 24, 2011 11:24 PM
Boost3dxEvO
Jul 9, 2009 07:02 PM
