do I need to replace all four
Old Jun 8, 2010 | 02:07 PM
9evolution's Avatar
The two front tires have worn prematurely I have had the car aligned, balanced and also rotated the worn tires to the rear. they are not worn dangerously bad but the front drivers side worn on the outside and the passenger worn on the inside. Anyway the two rear tires still look brand new no more than 5-6k on these tires. Do I have to buy a full set or can I just buy two to replace the worn ones?
Old Jun 8, 2010 | 02:09 PM
Neal@tirerack's Avatar
You can get away with two minimum of the same make/model/size.
Old Jun 8, 2010 | 03:51 PM
Wisky's Avatar
As long as you're running the same sizes all around *as you should on this car* , you should be able to get away with replacing 2 and rotating them every 2 oil changes to extend the life of the tires.
Old Jun 8, 2010 | 09:21 PM
rotarypower8's Avatar
Yeah definitely keep your two good tires and just replace the two tires that are worn.
Old Jun 9, 2010 | 02:12 PM
barneyb's Avatar
Are they worn in the center or just on the edges? If the centers of the worn tires have the same tread as the centers of the good tires, the diameters should be the same.
N1MR0D
Jul 4, 2017 08:47 AM
Gazika
Sep 27, 2013 07:57 AM
sam.hollis
Oct 8, 2012 01:30 PM
FushunEvo
May 28, 2009 12:10 AM
gregivq
10
Nov 24, 2005 06:35 PM
